Oh yeah it wasn't great but wasn't terrible. The bars had already been stressed and when I cranked them they actually twisted over the course of a year. Can't complain we got 320k out of them. When i upgraded to the HD bars though it rode like crap. Got a set of stockers though when I installed this lift
Sent while in 'Murica...
Edited by rdnckhntr94
Yeah I'll bet. Have drove cranked up pickups and would never do it to mine, rides smooth already and has as much clearance as it's going to get. I do have a couple raw spots on the "sliders" of my bumper but they'll buff.
I want my next to be a RCSB 4x4. Want to copy a hummer build from another site. Custom subframe & arms, D60 center running GM HD CV shafts. GM HD rack cranking stock knuckles & unit bearings. Lockers both ends hooking up 35's. Who knows if it will ever happen. Any dumbass can do a SAS, doing an IFS setup that uses easy to find parts takes more thought. The inspiration has 10 inches of front travel, not bad.
I want another truck. A GMT800, lowered on coilovers and 4 link the rear on coilovers. Just a 408 in it and make it autocross
She don't look too bad in this pic
Badass.
One of the best pics I've ever taken of it.. Top of test hill closing weekend
Edited by SarahsGMC
just got it 2 days ago. i work at a GMC dealer and after driving a 11' ram around for a while i decided i needed a new sierra. love the truck! and the 6.2 is just nuts
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 636 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
