Are We Giving The Correct Tire Size Advice?
mhenshaw
Going back to the gmt-800's I know people who had rubbing issues with 285's and I ran 2 sets with no issues whatsoever.
  • Replies 49
The definition of "fitting" to me is NO RUBBING AT ALL ANY SITUATION!. I tried the 305/55/20 with 2" level kit, with +30 offset (oem offset,very conservative) and it RUBBED.. I even trimmed up all the plastic i could, but refused to cut or bend metal on a brand new truck.
Yes the tires physically fit in the wheel wells, and I could drive the truck around, but it was a bad experience.. Parking lots were miserable.. Turning both left and right in drive, rubbed.. IN reverse FORGET ABOUT IT.. i would be doing like 4 point turns to get out of a parking spot.. as soon as that tire catches fender and it starts rubbing, its SOOO LOUD and obnoxious people turn their heads thinking that i smashed into another car or something..
SO my experience was 305/55/20 w+30 offset = unacceptable rubbing turning in drive, reverse, and even on slight turns if they are on an incline, or off cambler.. Or if you hit a bump while turning. It rubbed in all situations and didnt even need to be at full lock.
I ended up running the 305/55/20" tires with 7.5" of suspension lift and no one says they look small, they are just a BIG tire that doesnt work with less than 5" of lift.. People have had rubbing issues even with 2"+3" combos, still need to trim.. Same with 4" BDS suspension lift. Trimming needed..
Possible explanation: Some times different tire brands are sized differently, but labeled the same.. One companies 33x12.5 could be 33.5x13 and another companies tire may be 32.5x12 Its almost like some companies measure with the tread depth and some dont count the tread depth and measure from wear bars. And it is the width every bit as much as it is the height that contribute to rubbing.. thats why either a 285 will clear as a 33" tire or a 305 will clear as a 32" tire.
if it rubs it doesnt fit. saying it fits when it rubs is like saying my pants fit even though i cant sit down.
:seeya:
I see a lot of valid points here, but I think were doing the right thing by being a little conservative with our recommendations. I'm still going to tell people that 285's are about the limit, when they ask about the biggest tire that will fit a leveled GMT900...without rubbing. Then, when someone slaps the 285's on their rig...it still looks a ton better than the stockers...and they can take it off road without tearing off their mud flaps or ripping their inner fender out...and they can buy aftermarket rims later if they want to...all without touching a pair of cutters.
I would be hotter than a firecracker if someone told me 33x12.50's would fit, then had to find out the hard way they would only "fit" if I cut the heck out of my new truck. I would want to go put knots on that guys head for giving me bad advice...if I spent $1000 on tires that sounded like I was going to tear my fender off every time I backed out of the driveway.
A few years ago, I helped a buddy mount 38x12.50x16.5 Swampers on a '82 K20 with NO lift. Did they fit...yes...with liberal use of a sledge hammer and sawzall. Just because a larger tire will "fit" doesn't mean everyone will be happy with it.
Off topic somewhat,... but why do tires rub more in reverse than forward :seeya:
My understanding of this has always been because the front squats down a bit in reverse, kind of like the rear does when you are are going forward.
For the members asking what fits without rubbing, you need to be willing to trim. Stuff doesn't just bolt right up. The questions you should be asking is what will not work at all.
Put me firmly in the 'if it rubs it doesn't fit' camp. But I am off pavement a fair bit, often with heavy stuff in the bed.
I have to ask, based on your above post, what is your definition of 'what will not work at all'?
Were these wheels 8.5" or 9" wide?
I completely understand thay some of you think that even a little rubbing is bad. I however feel a slight rub is not a big deal at all. As far as you ripping off your fenders, I would be more worried about a mechanic not tighening my lugs and my tire falling off than the fender being damaged from rubbing. As far as not wanting to trim, I would rather trim before I cut my sub-frame and installed a 6" lift.
What would not work to me is any tire and wheel setup that you couldn't turn your wheels all the way (ie. you lose your turning circle). If you can turn you wheel all the way but it rubs, then you can trim to fix it. I would never recommend someone to get 33.5x13.50, but I would recommend them to get 33x12.5. Like some of you have stated tires measure up differently and trucks probally sit differently. So some may rub with a 33x12.5 some won't. But even if the truck does rub it is still driveable from the shop and it can be fixed.
I think the answer is obvious here....
YOU don't think rubbing is an issue, but the majority of this site does. So when someone posts a question and asks "what fits", we tell them. You're more than welcome to respond with a larger tire size.... just make sure you tell them its going to rub.
You ARE the exact reason I got screwed and had to cut metal on my brand new truck. When I confronted the person I confided in he said "oh yeah it does rub but I don't think its a big deal". He failed to mentioned that when he PMed me back initially with "oh Yeah they fit fine man".
Edit: :thumbs: if you can't tell, I'm still pissed about that. I did not enjoy cutting the fenders on my Denali. Although it looked perfectly fine when I was done (because I had experience with it on my silverado) it was a decision I made to not trim any metal on that truck. A little bit of plastic is one thing.... but not metal.
To the OP, why not just offer your opinion when the question comes up, and let others offer theirs? It is simply an opinion, not a statement of fact. What works for you may not even be close for someone else, even with the exact same setup.
For example, I have a friend that has a 2008 Sierra Ext Cab 2wd, with the 4.8 engine, his truck with the stock wheels, running the original General Ameritracs 245-70-17 tire rubs when the wheels are turned to the left and backing up down the driveway onto the street. Has done this since the day he picked the truck up new. I have a 2010 Sierra Ext Cab 2wd and have the larger 265-70-17 tires on it, running the same wheel he has, no rubbing at any time, even though the tire is about an inch taller. There are tolerances is specs for the building of the truck, and that is what makes his rub. The rub does not bother him at all, it just polishes up the inner fender where it hits.
I was pissed too... I had my first setup with 305/55/20s and 2" level back when these trucks were still fairly new and then the general concensus was.. "yah they will fit"... They rubbed like a bitch and i was PISSED.. It wasnt close, it coulda been 8.5" wheels, 9" wheels, 7" wheels, 10" wheels non of them were gonna clear the wide, tall, tire with 20/32nds of tread depth. Who wants to spend $35,000.00+ dollars on a brand new truck, running like a dream, then the very next day you install the level kit and 33s and you cant even drive it normally it rubs loudly and scares everyone in the parking lot?? Turned your brand new 35k truck into a piece of shit.
You might think that some trucks sit differently and thats why some fit and some dont, but it still boils down to needing 5" of lift to properly clear them, so its not like one guys 2" level kit is gonna work and anothers doesnt"...
As far as Im concerned theres no reason to recommend the 305/55/20 tire size to the guys with the level kits when there is the 305/50/20. it WILL clear with just the level kit, and there are a few a/t tires available in that size, and they look much better than the taller skinner 285 width option.
Blackout07 you know a lot about trucks and I respect everything you say but did you try on +31 offest? These trucks don't like the offset or wide tires. But the wide tires have room to turn in the fenders. There is a lot more room in the inside corner by the engine, than the outside fender edge.
I didn't try the factory wheels, but we are talking about of difference of 13 mm. That's not a big difference. At least not in terms of changing from "these don't fit at all, to they rub a small amount." Like Steve mentioned, these trucks do have some variance in stance, but not enough to allow a leveling kit to magically allow any one person to mount a 33x12.50 with no rubbing. Also keep in mind that that 13 mm difference was even more negligible when I added the 3" body lift. I never trimmed anything, but the cold hard fact is that those tires rubbed even with 5" of lift.
Are we still arguing about this?!?!? If it rubs, it doesn't fit... if someone considers rubbing "ok"... then i suppose a circle will fit in a square hole :thumbs: I'm gonna have to change my entire approach when people ask for advice on whether things "work" or not.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
