Fuel Pump Change
Hi
Okay so a 05 1500hd crew with 72k with no problems. I use this truck as the family camper hauler and as such travel extended distances a couple times per year. ( spring break was 2500 miles and fall will be 3500 with shorter trips in between) The truck runs great but I am concerned about losing the fuel pump on the road. What is the shelf life on the pump or should I just change it and be done with it. Thanks
I don't know what to tell you. My friend just replaced his on a 2000 Silverado and he had approx. 165,000 on his truck before the pump gave out. My brother's Suburban (2001) had the fuel pump fail at 115,000. It is hard to say how long yours might last.
there is no mileage to call it "worn out" at. One thing I've always noticed, they seem to last much longer in trucks where the driver refills the tank at 1/4 rather than waiting until it gets empty
+1 I never let my tank go below 1/4 tank. I've always been told to do that since the pump sits in the tank and the fuel keeps it cool.
Thanks for the input. Still not sure what to do. Going on a 3200 mile trip this fall and hate to get stuck in the middle of nowhere. As a rule I fill up when the tank is empty and never heard of the 1/4 rule but it makes perfect sense barring a look at the actual mechanics of the pump. It seems that cooling would be built in to the system with some sort of an internal sump as most people are not going to consistently refuel at 1/4 tank in a truck that gets 12mpg. anyone know if your better off getting the pump oem vs aftermarket. I usually get my stuff from gmpartsdirect. thanks Ken
You could replace your pump and have the new one die while on your trip. Quit worrying if you're not having any symptoms.
My dad bout a '94 full size blazer new, 2 weeks later the fuel pump went, the next one lasted over 200,000 miles still had it in there when i sold it. It is a gamble either way, I know people that can't keep aftermarket ones in there trucks.
...I never let my tank go below 1/4 tank. I've always been told to do that since the pump sits in the tank and the fuel keeps it cool.
I don't buy the "gas keeps pump cool" theory. Fuel in the tank is the same temp. as ambient air.
I do believe in the 1/4 tank rationale. Pumps typically prefer head pressure (they have to work less hard).
PS: I've been curious as well as to the OP's query "How long does a fuel pump last & should I change it out at X miles to be on the safe side rather than being stranded in God knows where"
I replaced the fuel pump around 90,000 miles / 10 years old. Fuel gauge was bouncing to empty, then would return to full after gas fill up. Also, had to wait a few seconds to start, like starting a diesel. The sock at the bottom of pump was blacken with small particles, brushes on fuel sender were worn, and wires at top of pump, insulation was exposed.
Right. The fuel pump is cooled and lubricated by the fuel running thru it. Keeping the tank above 1/4 min is important for keeping condensation out of the fuel which then causes problems with the pump. I was told by a mechanic whom I trust, that after 85k on a GM pump you are on borrowed time. But there are people here who talk about pumps lasting 185k. guess you just need to decide for yourself.
Oh? Don't believe the gas keeps pump cool theory? Try this: first stick your hand in a cooler full of ice water, then stick it in a cooler with just a block of ice in it without contacting the ice. See which one freezes your had first. Air is a poor conductor of thermal energy and when you can have a cooling media (fuel) in direct contact with the heat source (pump), the heat source will cool much more quickly.
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
