Transmission Code Help
While I was driving my check engine light came on. Stabilitrak, park assist and ABS also disabled and the line that is under the gear disappeared. I pull over and turned it off and then started it again and the line returned but everything else was still on. I checked the fuses and some were loose so I pushed them back in and the only thing that stayed on was the check engine light.
I got the codes, P1825 and P0700, then later the check engine light went off. I don't know what the issue could be, any help would be awesome!
2007 Yukon Denali XL
I found another site that said it should be covered under the powertrain warranty so I made an appointment.
Also does anyone know what warranty the air bags are covered under? The light is also on, I can't find any specific warranty info for GMC but Toyota says that the powertrain warranty covers air bags: http://www.toyota.com/owners/warranty/
Both codes deal with the transmission. Pretty sure they would be covered by power train warranty. Just Google the codes and you'll get plenty of info.
