Finally Got New Wheels...pics Inside
bhsballer76
Finally got my new wheels and tires put on. Went with 20" Black SS Replicas. Tires are 275/55/20 Firestone Destination ST's..
Thoughts?
Should I level it out by lowering the rear or raising the front? Which will keep ride quality closest to stock?
Do you tow anything or load the bed? you don't have much room in the back if you do to account for sagging. she looks good the way she sits to me.
I tow a 5x6 trailer with an mx bike every once in a while...Thats about it...
Removing the rear blocks will keep the ride stock feeling. The new wheels look great :)
Does this require a lowering kit??
Thanks!!!!!!
no i think hes referring to the stock block which can be taken out
Thanks!!!!!!
As mentioned,... No.. it doesn't require any other parts. It's a freebee :fume:
well your going with the SS theme so i would definatley lower it, and lowering it is extremely easy like, like others have said, all you gotta do is take the little rear block out
Looks cooL! I would remove the rear to level out, with those wheels I think a bit lower would look bad azzz!
