Cutting Concrete Block
Mossyoakglock
I need to cut a piece of a concrete block wall out in our garage. I need to cut 3 inches off the face of the wall/block that is about 7ft long making a sort of pocket in the wall. It will probably be about 14" off the ground and the cutout will be around 10" tall. I'm going to put a piece of steel across the top to help support and distribute the weight as well.
What is the best way to cut this? I can't rent a concrete saw from Home Depot since I don't have the space to use it. Would it be better to get a diamond blade for a skilsaw or for an angle grinder?
Any other thoughts or methods somebody can suggest?
if you can find a 7 1/2" worm drive saw will work better than a regular Skil. a blade for cutting concrete is always best. have a hose with water to keep the blade cool, and you'll be ok. you'll need a bunch of extra blades..
good luck
For that long of a cut, buy yourself a diamond cut blade. The standard composite blades will wear down extremely quick and will take much much longer. Whichever skil saw you use, make sure dont care much about it or need to depend on it in the future..
Most likely you will burn it up pretty good and throw it out of alignment..
Also you will need to look at the max cutting depth of the circ saw.. Depending on what size blade you have, it may not get all the way thru.
Personally i would find a way to get a concrete saw to fit in there, and or rent a rotary hammer with a chisel on the end, use the circ saw to jsut score where you are going to cut , and finish with the rotary chisel..
I also agree that when cutting , keep plenty of water on the block / and blade at same time. Also goggles and a respirator would be a great idea. If u dont have a respirator, use a face shield of some sort and you do not want to breath in all that dust... Been there, done that. :thumbs:
+1 on the diamond blade.
You could also put a diamond blade onto a 4 1/2" grinder to make the cut. It may be a little easier to handle than the circ saw in a odd position.
Also, if you are going to use water as suggested, please plug the powertool into a GFCI outlet or threeway splitter. SAFETY FIRST.
Are you talking about cinder block? If so, I'd take out whole blocks at the joints, and fill-in/fit to the new header from the block line. A chisel works fine. Maybe I didn't understand?
Yes, it is a cinder block wall with a regular wall (2x4s and drywall) on top of it. I attached a very crude picture from paint so you can see kinda what I want to accomplish.
i'm sure you know what you're doing, so i won't preach...but if it's a load-bearing wall make sure you're not weakening it to the point of failure. just keep in mind that that wall may need to transfer dead load, wind load, snow load, etc. to the ground.
Being that it is cinder block, I dont know how you are going to accurately and delicately cut in 3"and then chip along the back side of the pocket without knocking out the rest of the block..
Why not remove the whole blocks, then replace with smaller bricks that are not as deep and re mortal them in, to resupport the wall again. Also a lintel should be installed to carry the load...
I also agree with what is said above about temp support braces while you are doing this work. I would use build a temp beam out of minimum 2x6, if not 2x8, then support the beam going to solid ground using also 2x6 / 2x8's. Wouldnt be a bad idea to sister them together with glue and nails. I hate to preach about this like PORTER did not want to do, but he brought up a great point that should not be bypassed or assumed the wall will hold or the roof wont collapse.
My thought was to make the cut and support it while working then put in a piece of angle iron to support the weight and then backfill in the holes with concrete. My thoughts about cutting 3" off the cinder block are the same. That's why I thought I'd ask before just cutting away.
There is already a 2x4 or 2x6 that runs along the top of the concrete wall sandwiched between the blocks and actual wall. I would not touch this piece. I would probably put the steel/iron underneath this for added support.
I might just give a concrete and coring company in town a call and see if they give free estimates and see how much they will charge.
I don't mind doing this kind of stuff and am comfortable doing repairs, etc but seeing that this might be a little more involved and require more/specialized tools than what I have this might be a job for somebody else.
Wouldnt be a bad idea to call in someone professional at all :dunno:
Why are you creating this pocket in the wall anyhow?
+1. I pretty much know how I'd do it, but can't (won't) attempt to explain it on a forum for fear of making it sound easier or simpler than it is. I've built a few houses with my dad (who built for almost 50 yrs), have lots of tools, and have a good "feel" for it. It's not possible to describe in words, without seeing it all first hand. Heck, those TV shows that "show you how" don't show you how... they just give a snapshot version, without all the sweat and cut hands.
    Gilkey96
    Gilkey96
  • Who's Online   4 Members, 0 Anonymous, 873 Guests (See full list)
    • Replace the fuel pump with an OEM AC-Delco.
    • Hello, first time posting here. I have an 03 Chevy 1500HD with the 6 liter gas engine. The truck ran fine until the fuel pump died on me and had to get it towed. Replaced the fuel pump with a precision pump from O’rileys and changed the fuel filter while I was there. The truck will run and drive now but it wants to idle around 500 rpm when in drive and it tries to stall if you touch the gas. It drives fine though, just doesn’t want to idle. Put a fuel pressure gauge on the rail and only have 50 psi. I guess these trucks should have 55-62 psi to run right. I thought the regulator might be the issue because when I would unplug the vacuum hose it jumped to 56 psi. Replaced the regulator and no change. The only thing I can think of is that I was sold a faulty fuel pump. Any help would be appreciated because I’d rather not have to take the bed off again if I don’t have too. Thank you!
    • I've been wrenching on GM trucks for 17 years. And I need to get something off my chest because it's been weighing on me for a long time. After all that time, all those motors, all those people standing in my bay, I've figured out there are really only two kinds of owners. The ones who already know about this. And the ones who are about to find out the hard way. A guy came into my shop a few weeks back in a 2018 Silverado 5.3. Sharp guy, maybe 35. Knew his truck cold. He'd been on the forums, read the threads, done his homework. He only rolled in so I could double-check a little module he'd already plugged in himself. Wanted a second set of eyes on it. Ten minutes, in and out, drove off happy. Two days later, a completely different story walked through the same door. Older fella this time, in a 2016 Sierra. Gorgeous truck, clearly babied, not a scratch on it. Wedding ring. Looked like a guy who took care of his stuff. He was in because his engine had started knocking on the way to work. And by the time I got the valve cover off, I already knew it was too late. Lifter collapsed. Cylinder 5. Camshaft chewed up. The whole top end shot. Same kind of truck. Same motor. Same roads, probably the same dealer. The only thing separating those two men was information. I've been at this since 2008, and I've worked on everything GM puts out. Silverados. Sierras. Tahoes. Yukons. Suburbans. Escalades. The 5.3 and the 6.2. Doesn't matter which badge is on the tailgate. They all carry the same problem. So here's the information one of those guys had and the other one didn't. It's called Active Fuel Management. AFM. GM started building it into their V6s and V8s back in 2007 to squeeze out a little better mileage on the highway. Maybe a mile or two a gallon. All to hit government fuel economy numbers. The way it works, the motor quietly shuts down half its cylinders when you're just cruising along. And the little lifters that pull that off have a tiny pin inside them that's constantly clicking in and out. Lock, unlock, lock, unlock. Hundreds of times a drive. Thousands of times a week. Eventually one of those pins wears through. The lifter drops. And it starts grinding the camshaft down like a chisel on butter. And what nobody tells you is that the shudder you feel around 40 or 50 mph? That's the system cycling. Every single time. Here's what really gets me. The pre-2007 trucks, the ones without AFM, they're bulletproof. I've got customers still daily driving them with 260,000 miles on the odometer. Not a problem in the world. GM took a perfectly good motor that would have lasted a lifetime and bolted this system onto it. And it is wrecking engines that should have run forever. The guys who hang around the forums already know all of this. So do the techs. They handled this years ago. They didn't sit around waiting for the dealership to mail them a warning letter, because that letter is never coming. It's the guys who figured somebody would've told them who end up on my lift. And I want to be clear, because this part matters. Maintenance has nothing to do with it. I've torn down motors with barely 30,000 miles on the clock. I pulled apart a Tahoe last summer with 24,000 on it. Practically a brand new truck. Owner had it less than a year. Spotless oil. Best synthetic money can buy, changed early every time. Made no difference. I've seen guys with full dealer records, every interval stamped. Made no difference. The oil changes were never the problem. The pin was. And no amount of babying that truck stops that pin from cycling every single time you drive. That's the part that eats at me. These are good motors. Take the AFM out of the equation and a 5.3 or a 6.2 will run 300,000 miles and never blink. So a few years ago I started telling every single owner who comes through my doors the exact same thing the smart guys already knew. Get yourself a FullForce disabler. It plugs right into the port under your dash. Couple of seconds and you're done. It just tells the computer to leave every cylinder running, full time. No more cycling. No more beating those lifters back and forth every time you turn the key. It doesn't reprogram anything. Doesn't touch your tune. And unplug it before a dealer visit and there's absolutely zero trace it was ever installed. I've had customers come back at 40,000, 60,000, 80,000 miles after I put one in. Zero issues. The trucks run smoother. And the lifters aren't getting beaten to death every single drive. I won't sit here and tell you it's magic. A lifter that's already damaged is a lifter that's already damaged, and this won't un-ring that bell. But it takes away the one thing causing all that wear in the first place. That's the whole game. You don't need a five-thousand-dollar delete. You don't need an expensive tune. You don't need to tear anything apart. You just need to stop the cycling. I'm not writing this for any company. I'm writing it because I'm tired of watching the guys who didn't know pay four and five figures for it. I'm tired of being the guy who has to break the news. I'm tired of knowing that the guys who did know fixed the whole thing for the price of a tank of gas, and the only difference was that somebody told them first. If you drive a Silverado, Sierra, Tahoe, Yukon, Suburban, or Escalade from 2007 or newer with a V6 or V8, you've got AFM. You've got those lifters, and they're cycling every single time you drive. So be the guy who already knew. Not the one I'm scraping metal out of next month. EDIT: A bunch of folks asked, so here it is. The one I put my faith in is FullForce. This is where to find it: https://www.tryfullforce.com/products/fullforce™-afm-dfm-disabler They back it with a 60-day guarantee too. I've handed out more than I can count and not one's ever come back to me. Not one. See less
    • Thanks for following along. I'm not author material, my tenses are all over the place and an editor would have a heck of a time cleaning up after me. Reading and writing is still a fun pastime though.   My new scanner came in yesterday, wow, where the heck has this thing been?! It connects right up to the Blazer, there's all kinds of bidirectional tests like EGR activation and percentage, toggle the fuel pump relay, EVAP purge valve, IAC control, AC relay, reset the transmission's adaptive learning, toggle shift solenoids and TCC lockup, and I can reset fuel trims with the click of a button...all things I could have used over the last 60 days!   It's also telling me there is a stored code in the ABS module for front left wheel sensor open and something about the brake switch. The ABS dash light works. It illuminates normally during the self-test at key on/ start and that's it. I cleared the codes and will see if they set when I take it out later. That, and I'm going to get (hopefully) real data on timing and cam ******. The PID's are there.   I connected the tool to my truck...holy smokes. Newer vehicles make early OBDII vehicles look like 8-bit, pixelated, early Nintendo stuff. This? This is like wearing 3D virtual reality goggles playing one of those elaborate, cinematic video games with seasons and plots in comparison. There are SO MANY modules and SO MANY tests and SO MUCH data. There's a scanner sequence for filling the coolant...   End of the day, it's a tool with way more power than I need, but the versatility to do old and new is there (and I need an adapter to connect it to my OBDI Camaro). It will allow me to do the first pass of diagnosis when out-of-warranty vehicles need help, and it will enable more DIY maintenance like brake system bleeding, ABS bleed, etc. I probably over-bought here, but, mission is accomplished.   Enjoy your Sunday...I need to shut this machine down and go get ready for the week ahead.
    • Not that I've read, after all the issues they've had in the past I'm pretty sure they learned their lesson.
