Sitting on 20's
LarryE
Since we get alot more traffic here than in the street board right now    I'll post these here first then move them
I agree much better than stock
Nice looking truck Larry
:D
Those... are..... sweeeeeeeeet!
Are you just now putting those on? I thought you mentioned something a while back about getting new wheels.
dance.gif  Very cool! dance2.gif  Can you give some details on brand, size dimensions, weight, source, etc.?
thanks
Wow, your truck just keeps looking better and better :D
I've never really been into sport trucks, but when it's done right...  :thumb:  :thumb:
