Replace Gmt800 Fogs With Par 36 Lamps?
So it would seem the GMT800 Sierra's fog lights are about 4.5" in diameter - in other words the same size as a PAR36 bulb. Mine are full of water and condensation, one doesn't even work right. I want to replace them with something a little more useful. Somehow I managed to shoehorn 9005 bulbs into the fogs in lieu of 9145s. A nice improvement but still have the moisture and water ingress problem.
I was considering putting some PAR36 LED bulbs in their place. A few are available that will far and away outperform halogen bulbs at a fraction of the current. Does anyone know if there's a bracket available to retrofit a PAR36 in place of the factory fogs or am I building my own bracket?
An interesting note - you can get aircraft landing lights in PAR36, 12 volt. :jester:
Yeah I work around them lights and even in sunlight they can temp blind you, so you will piss some people off drivin with those on at night lol
I put 55w HID kit in my fogs.. Bulbs size was a 9005 i believe (the high beam bulb ).
Love em! wouldnt have any other way
i have a 2001 silvy, with the shitty fogs, not the big ones like on the 03+. i put 55w HID in my fogs and they are now very bright and im very happy. no modding or cutting to fit bigger bulbs
Not interested in HID retrofits.
Retrofitting would mean it was actually done right, not just dropping a China crap bulb into a halogen housing. :jester:
Still, I prefer LEDs for all my lighting. Low amp draw, high intensity, and instant on to full power. My emergency lighting is now all LED and I kinda want to continue the trend.
I'm thinking of foregoing the round PAR36 and fit a pair of Rigid Industries Dually lamps into the fogs. They should be small enough to fit.
Don't get me wrong, I'm totally with you on LEDs. Hopefully traditional driving lights come down some as I'd like to add a set to my truck.
I finally got my POS fog light out and wow, what a mess. Water ingress sure didn't do the chrome any favors. As it turns out the lamp is nearly FIVE inches in diameter, and the opening is nearly 5 7/16" wide. Lots of room for different kinds of lamps. Just need to find one that's suitable now.
As the saga unfolds I came across these:
http://www.tunersdepot.com/Lighting/Fog-Li...erra-94871.html
Looks interesting but I'm reluctant to order anything from a "tuner" store. I'm looking for performance lamps, not Fast and the Furious. There's no mention of lumens, lux, or even LED wattage so I doubt they're much more than show pieces.
I found a site that has replacement OEM lamp assemblies with bracket for some $60ish a pair. I may opt to use the factory fogs as normal and add LED auxilliary lighting on a push bumper or something.
Ideas and comments welcome fellas!
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
