Broke ....
I can do that frame in just over one 8 hour day. Actually, with the lift stuff, probably right at two full working days. I'll be damned to tell you how many hours it pays but for $1500ish, I'd do one at home, all day long and twice on Sunday. :thumbs:
  • Replies 132
I feel as though they dont want anyone welding on the frame due to liability to GM. These frames can without a doubt be welded. Another thought is that any welding or heating of the frame will cause the rust proof coating to be damaged. If you are up for a frame swap then I have to say my hats off to you. I hope this all works out for you.
Of course, welding on ANY frame can be a liablity but you can't just go blindly welding on this frame. If you overheat it, it is junk as it will loose all of its hardness and fold like a pretzel with even a good smack from a 10" sledge hammer. So while they can be welded on, it is a lengthy process. I'd still do it before putting a frame on it.
Idk about that. He's good at what he does, not saying u aren't but how can u do it in less than 2 days and he says 6 days.. that's a big difference.
Because I've done at least 6 of them, that's why. Believe your friend dude. You obivously are and to the tune of $3500 for a $200 repair, no less. Enjoy. :thumbs:
Just because they dont "recommend" doesnt mean it cant be done. they dont recomment running larger tires, cranking up torsion keys, driving extended periods with the lower air damn removed, and a bunch of other things that us truck owners have done with no issues.
I have a aluminum wheel on my 2005 sunfire that has 180k on it, back at 120k a tie down rachet fell off a flat bed that I had no coice but to run over, it took out my tire and split my wheel. I could not find another matching wheel anywhere, and didnt want to replace all 4. I had a local welder weld and repair the wheel. It turned out to be nearly perfect balance and at this point i could not find the spot of the repair on the wheel. This is not recommended by any standard, but I made sure the welder was qualified and it only cost me $50. This ended up being a great fix. Wheel repair and tire outed me $150, insurance quoted over $1000 and I had no body damage.
Now are you saying 200 to weld or 200 for a frame replacement.. mind u.. im awaiting to see if gm will replace it costing me 0$. Not saying im doing the frame or doing the weld.. kind of checking all ny options first to see if I can get it payed for..
Nevermind dude. Simple conversation shouldn't be so difficult..........
Options have been given to you. Good luck.
Im confused sorry.
Do you think GM will cover your lifted trucks frame that is damaged right where the aftermarket suspension bolts to the truck? Do you know the front crossmember of your truck is cut out for your lift kit?
Also I would pick to have my frame welded anyday over getting a frame pulled back into shape after a wreck. Go to any bodyshop around you and they will be pulling/stretching frames back into place. They don't swap out frames for a wreak so what the difference in your case.
Take our advise and get someone skill to weld you back up and be done in an hour.
Well thing is the frame I would get would be from a truck that was totaled from water damage.. so the frame is fine.. im going to ask him.to weld it if gm falls threw.. he knows alot of people and thinks he will get it covered ... the lift is not what caused the problem he says ..
I appreciate all the help and info you guys are giving me.. Dont get me wrong, u guys know your stuff about this topic and i appreciate all the help. Its hard having you guys and my dad and my mechanic all trying to help me.. Im not saying that your guys answers are wrong or right.. Im just trying to exhaust all my options before i decide how i wanna deal with this. Im going to talk to him about welding the frame back together, BUT i want to atleast "try" to see what gm says... Its worth a shot.. Next will be welding.. im sure i can show him all the info you guys have told me and maybe he will rethink or say yes to that.
If your frame has been modified in anyway all warranty will be void. If someone knows someone, who knows a guy that can fix this for you, well more power to you I guess. This is turning into a shady scam over a $100 repair, weather its you, or your buddy, or GM someone is lossing their ass on this. And thats a damn scam!
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
