1989 Gmc S15 66,000 Miles (v6 4.3)
My wife's first car/truck is out of the garage after about 10 years and runs pretty good. It's a bit rough so after a tune up I took a new code reader to it and wanted to see what I got back. OMG!!! I have the following codes:
14 - Coolant Sensor - Signal Voltage low or shorted
31 - CAM Sensor Circuit Problems, Park/Neutral Switch
32 - EVRV Error, EGR Valve Diagnostic Switch - closed on startup, MAP Sensor Signal - low voltage
33 - MAP High Voltage During Idle
34 - MAP Low Voltage During Ignition On
41 - CAM Sensor Failure, Cylinder Select Error, EST Circuit Open/Shorted, Ignition System Fault
43 - ESC - Circuit Problems, EST Low Voltage
51 - Computer Problem - Faulty, wrong or incorrectly installed PROM or ECM/PCM Failure
52 - Calibration Package Chip or ECM Fault or Oil Temperature Sensor Fault/Low Engine Temperature, Faulty or Missing PROM, ECM Problem, High Voltage
53 - System Voltage to High (>17.7 volts to ECM) or EGR System Fault or Alternator Voltage Not Normal or Vehicle Anti-Theft Fault
54 - Fuel Pump Circuit Fault or Mixture Control (M/C) Solenoid Fault or ECM Fault, Fuel Pump Relay
55 - ECM Fault or Oxygen Sensor Circuit Fault
I REPLACED:
EGR VALVE
PCV VALVE
MAP SENSOR
WIRES, etc.
I disconnected the battery after trying to clear the codes with my Innova 3140b and still could not clear them. At this point I think the ECM must be failing since there were multiple codes pointing to that and that could be causing everything else.
Anyone venture a guess or some guidance here? I have no clue what to do next other than the ECM and see what happens then...
I REPLACED:
EGR VALVE
PCV VALVE
MAP SENSOR
WIRES, etc.
As stupid as this sounds, because its been sitting so long I would disconnect the neg post from the battery - wait an hour or so then hook it up and take it out for a spin. I bet you anything that you wont have half of those codes when you come back.
I dont know why but my 88 and 89 both do this after sitting - they throw so many codes they shouldn't even run - after running for a bit and going 25 miles or so they almost always clear (with exception of evap or o2 which i have to reset the computer again to get rid of)
try it, can't hurt
Also have you checked the voltage to the ECM?
-Takko
It looks like nothing has changed. Funny thing is the codes won't even clear. The only code that cleared was 43. I am thinking the swap of the ECM may be the best course of action. I am looking to order the service manuals and electrical diagrams to do some further testing.
If you look at #53 (system voltage too high 17.7 volts). The first thing I would check is the voltage. If it is that high it might have fried the ECM.
I just ordered the factory manuals. I will try to get to the ECM this weekend. I assume if the voltage is too high then I have an alternator/regulator issue. The truck was garaged for ten years and has had to have multiple jumpstarts (not all by me...) and several batteries since it sat for such a long time between runs. I wonder if a jump may have caused a surge. If the voltage is within range then I will change out the ECM, if not - then I need to get it down first. Thanks!
Not sure how I got a double post there. Must of stayed in memory or something. Sorry!
Wouldn't a quick check of the voltage at the ECM fuse work?
Check and see what the voltage is at the battery while the vehicle is running.
I am about to scream. I go to put in a used ECM/PROM/CALPAK and then I see the heater core leaking. I replace that, put in the used parts and guess what... THE SAME CODES!!!! I am thinking that there must be a bad ground or some voltage issue. I think I need to take a step back and check out all the wires at the ECM harness for proper grounding, voltages and resistances from my GM Manual? I assume that would be the best course of action followed by checking all the sensors? I can't figure out why I get persistent codes telling me the ECM/PROM/CALPAK is bad... I also replaced the CTS and the code 14 is STILL there and I still have no change in the car temperature based on the dash gauge.
HELP!!!
GM uses 2 temp ssensors, one to drive the dash gauge and 1 for the ECM.
  • 3 weeks later...
Try and drive it for like 25- 50 miles and see if it reset it's self. That's always works for my truck after I disconnect the battery. I was told that the ECM has to collect information on all the sensors before it will reset completely
^^ What he said. My dad's 88 sat for about 2 yrs and once I got it running again it showed all kinds of codes. After driving it about 50 miles most of the codes didn't show back up.
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
