back in a white truck with a TAD more power
  • Replies 55
with trimming and serious cranking
So you didn't lift it? Just trimming and a full on TB crank fit 35's or you installed a lift and had to crank the TB's and trimmed?
Sorry, I figured if I didn't someone else would ask. I have seen true 33's on the '11's with just a torsion crank.
the truck has a 6.5" BDS lift, it is NOT cranked OR trimmed. 35" toyo's and 20" novakanes
the question was "did i have to put the lift on to clear the tires?" i BELIEVE i could have fit the tires WITHOUT the lift with lots of cranking and a decent amount of trimming, but i DID not do that.
Didn't mean to upset you. I was confused because it looked like it had a suspension lift on it for sure and I misunderstood your post.
you didnt upset me at all, i was just trying to eliminate all the confusion lol
thanks guys!
Really? You had to do this? I need a raise.... Truck and Paycheck. If I were to build a truck (again) this would be damn near the twin.
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
