Breaking in? I did my truck at 10k ad the camaro at like 750 miles :)
Ryan
How many 6.2l owners are actually running 91 octane like they are supposed to?
It is shocking the number of owners we encounter who are running 87.
Sent from a jelly bean.
My gas cap and manual state 93 premium or E85 for the 6.2. Maybe this has changed since 2010?
I have been 100% E85 for over 3 yrs now
Ryan
What about places that don't have 93 or E85. Max here is 91 and that's what I run in the 6.0
Nothing but premium and E85 in both of my 6.2's since day one.
It is sad, the folks who have the newer 5.3L and 6.2L wanting economy and running 87. We have seen the 6.2Ls loose as much as 40HP due to running 87. They are 10.7:1 compression, can't run efficiently!! :rant:
Ryan
91 is the minimum for the 6.2L, and 89 is the minimum for the 5.3L on the NNBS. I would have to check Justin's truck, but I think my gas cap just says flex fuel capable. Most dealerships will not tell consumers that they need to run the higher octane, for fear of driving them away.
We have to tell the dealerships to leave the tanks empty, that we will fill them up on our own when we leave the lot (when purchasing).
I run nothing lower than 93 octane at all times. I didn't know that the 5.3L was supposed to use 89 I always used 87. If I would have known that I would have ran the 89 if not 93.
I had a good sales man he filled mine up on premium :)
See it everyday.
Bud of mine couldn't believe the difference in how good his '12 nht ran on premium. His dealer said nothing about it.
GM actually did all development testing on the 6.0 and 6.2 on premium. Seen/felt a large difference in a friends hd 6.0 after converting it to premium as well.
Never seen a difference in running anything higher than 87 in and of the 5.3's personally.
Mine did as well, on both of my 6.2's.
Ryan
When I was at the dealer we had the lot kid fill a few VW diesels with 87. That makes a neat noise. :lol:
How many 6.2l owners are actually running 91 octane like they are supposed to? It is shocking the number of owners we encounter who are running 87. Sent from a jelly bean.
I run 93 octane Premium, always.
Ok guys, Ive been looking and looking but cant seem to find what Im looking for. Im looking to replace just the muffler on my 6.2 but dont want a tone of drone and would like to keep all stock piping except for the muffler. I like the sound of Magnaflow and cant seem to find a 3.5in to 3.5 out. Anyone running one? Im also open to ideas what mufflers is everyone running?
    Smitty462
    Smitty462
  • Who's Online   5 Members, 1 Anonymous, 705 Guests (See full list)
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
