Eat your heart out EB fans. This is no b.s. and no I was not drafting a semi, going downhill or gettting pushed by a good tailwind.
Not bad!
I can't drive normal so I only see 11-12 :lol (E85 powered)
Ryan
This average calculation was started with the truck still running ethanol on the trip up (100 miles one way and I went up and back the same day) so it still had 3-4 gallons of ethanol in the tank when I filled it back up with premium fuel for the ride back home.
Edited by ChevyTech77
2012 AWD Sierra Denali 2,300 miles since new (3/27/12) and average mpg is 17.8. One 500 mile and 2-200 mile trips, 55-65 mph 2-lane, no hot-rodding, use cruise all the time, Shell premium 91 octane primarely but a tank or two of Murphy 93 (WM) mixed in, no E85 around here. No mods planned except all AMSOIL 100% synthetic fluids going in before 5,000 miles. That raised my awd CTS4 mpg nearly 1 mpg.
Good to see that! Just called on a 2010 GMC with a 6.2 & asked the salesman to tell me what the avg mpg was... 13.2 with 53,000 miles on it. Hope the guy had a lead foot because I am still going to go check it out.
You know the avg mpg setting can be changed right? I reset mine at each fillup
Ryan
Ryan
Did not know that. Have always just left one main one alone. But that was in a 2007 LBZ Dually. Thanks
Mine probably averages that as well but I only have a 2 mile drive to work and I'm usually running ethanol these days.
Don't buy it for the fuel mileage. My post was just to prove that a similarly equipped EB F-150 DOES NOT get a ton better mileage than a 6.2l GM. ESPECIALLY when they are towing a load then the GM 6.2l kills it.
Ryan
Does that also apply to a 2008 Silverado? If that can be reset I didn't know it and don't know how. My truck was showing 17.6 yesterday when I sold it to my son.
Not many options other than the Max Trailering Pack.
The most important one. looks good :thumbs:
You got that right!
The main reason I wanted a new truck was to get a crew cab. My old truck was an extended cab. Also, the 6.2 with the Max Trailering Pack should make pulling my 7' X 16' enclosed trailer a breeze.
Ryan
Should be I could in my 08 Tahoe
When you hit the mpg screen press and hold the checkmark button
Ryan
I never reset it in any of my vehicles, the aveage mpg is the only thing of importance to me. My last truck was a 2010 Sierra All Terrain 5.3L E cab and in the 24,000 miles the aveage readout was 17.7 but I also drove almost 1/2 of those miles in winter using AUTO 4x4 mode all the time. The All Terrain pkg rode too rough for my taste.
I too never bought it for mileage, needed a CC for business and wanted a top line truck w/o AFM.
Edited by elcamino
If you collect your gas receipt/milage data you can calculate it
If you continually reset it you can catch possible issues quick (drastic drops in mpg that would go unnoticed if you didn't reset)
To each their own
Ryan
Just ordered my Auto-Cal from BB. Anticipation is killing me, just like all of you. Any tips from you guys with an Auto-Cal on my next steps when I finally get it? I thought I should receive an e-mail from BB but still waiting. I know they are really busy and a small operation respectively so I guess I will just wait patiently :tumbleweed:
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,299 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
