How can you tell if a hub is bad
I had the passneger side replaced over the summer, and with 98K on the clock, im sure the driver side is not far behind, unless it was replaced before I bought the truck. I got it last Dec with 87K on it so I guess it could have been replaced.
Ive heard some of you guys say that a bad hub bearing will make a roaring sound when driving. But, how do you tell the difference between road noise, tire whine, and the bearing roar? Not to mention having to hear it over the wind noise.Plus since I installed the BL, Ive begun to hear all kinds of strnage noises that I never heard from the truck before, like the steering shaft clunk. Put the tire noise at speed together with a steering shaft clunk when turning, and me being paranoid about my hub being, and I find myself constantly checking the front hub. But, good news is that it always seems tight as far as I can tell.
Does it make a distinct sound?
Will it make any sounds a low speeds, or only at highway speeds?
it will progessively get worse as you go faster. It will be a distinctive hum noise. It will be hard to hear your radio at regular volume.
Where the heck did the side mirror go on the red silverado? :lol:
So I would hear the hum over the radio?
You will get more of a growling noise than a hum. It will progressivly get louder. A bearing can be bad and growl, yet have no play. Have seen that many times. If it is the fronts you can check while turning at higher speed. The bearing sound will get worse with speed(similar to tire noise). If teh left one is bad the noise will get worse when turning right as your loading the left bearing. Opposite is true for the other side. Any questions feel free to ask.
Sometimes turning in a parking lot at a slower speed will tell you too. The side that makes noise on the turn is the bad bearing. Placing a load on that bearing.
I've replaced hundreds of full size truck hub bearings that didn't make a peep of noise but were about ready to seperate at any minute. Jack it up and check it for play.
They can also be very noisy and have zero play.
True as that is how most every bad car hub bearing that I've ever seen, is.
Is it possible that when you load the bearing (by turning or whatever) the action silences the bearing? I thought for sure that it was the passenger side in my truck that was bad, but when I turn left the sound goes away.
i just replaced my left hub at exactly 100k, it had very little play and was rumbling real bad
You know, this isnt really helping any. Besides the fact that you cant describe a sound by typing, there is a lot of contradicting information here. Sometimes there is play, sometimes there isnt. Sometimes it makes noise, sometimes it doesnt. Sometimes it will make it worse when turning, sometimes it will make it quieter. My head is spinning, and Im no closer to knowing if my bearing are good or bad.
I appreciate the info and input from all that contributed. Im just pointing out the contradictions here.
If you're worried about it at all, just spend a bit of money and replace the bearing. It's an easy job, and new parts are relatively superior to anything with any amount of wear. Peace of mind will ensue.
    • Most online suppliers and Amazon. All have noted "not for use with Bose speakers".
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
