1500 tow mirrors
Knepp1bj
been seeing a lot of brand new F150s around my area lately with tow mirrors....
wonder why you dont see a lot of 1500 chevys with them?
if you have a new style 1500 with tow mirrors post a picture. are these not very common for chevys or do they just look odd?
they look good on the fords
in my opinion tow mirrors look good on some 1500s but not all. I wouldnt mind a set. I would trade someone my DL3s for a set
ill go take a pic later... theres a new body down the street with a set. i think its a regular cab. its like a company truck
here's mine on the day i picked it up. came with them from the factory.
ill provide the 2wd pic in a lil while. im in process of getting the GMT 800 version of those
I agree, some trucks look good... some dont with them. I think the trucks that look good are the ones with bigger tires, and/or lifted trucks. I use the slip on style and they work great in my opinion for the occasional tow. If your towing all the time, I'd suggest the OEM style, but if your only towing occasionally, then I'd suggest these...
http://www.ebay.com/...ssories&vxp=mtr
They snap on and they fit like they belong and not just stuck on. :thumbs:
I've got 'em! (signature picture, sorry dont have a better one to post from my work computer)
ive got some, not sure where the hell my pictures are, but its also on 7 inches of lift, not sure if im in love with them on a stock truck though
Looks wasn't a concern when I swapped. I was looking for functionality because that is more important than looks to me.
Agreed. I tow 30ft of trailer and they are perfect.
See my signature pic. I like the DL3's but every time I consider taking these off they prove useful again. I do tow a boat all summer and a large sled trailer all winter in addition to alot of Misc stuff.
mine tows several boats and they help. I hated them at first but you can literally see everything. no blind spot at all. driving my dad's yukon its hard because he has the regular mirrors. they grow on you looks wise. and my truck is going to be slightly lifted soon enough. I don't think i'll drive a truck without them
I have them on my 2011 1500 ext cab and am getting used to them. They block some view until you get familiar with them but the dual mirrors really work whether pulling a trailer or not. I pull a trailer in the summer taking my 1942 Farmall H to the local tractor shows and then I pull a trailer to all the local football games for the high school.
Karl
  • 4 weeks later...
Can you guys possibly point me in the right direction on which aftermarket extended mirrors to get ..I been searching ebay and tthey have a bunch but I really dont want to buy a POS if possible....let me know your thoughts thanks.
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
