Got a set of GM 22's on the Sierra
wifeysdenali
yes I do, had the corsas put on last week. So yeah, looks like I'm done with the big mods for a while!
  • Replies 34
This was the rim and tire size that I want to install on my stock height 2012 Yukon Denali.
What is the offset of these rims, and how far do they stick out from the end of the fenders?
Thanks in advance.
Thanks in advance.
Thanks in advance.
They really fit like stock since they are basically a gm option rim. Tire is a bit wider since I got 305's, stock I think would have been 285. Rims are 9" wide with a 31 offset. They stick out just a touch more then my oem denali 20's did. Fills out the fenderwells nicely.
Thanks for the information, your truck looks great.
Did you use the stock TPMS sensors from your original rims?, or did you replace them with aftermarket?
Have you had any problems with the TPMS since the tire and rim swap?
Thanks again in advance.
I used the ones that came with the new rims. They seem to be working fine
i just did the same thing. wished i would have got the same tires you did though. wasnt sure so i played it safe
nitto dune grapplers. the only thing i dont like about them though is that because the tread wraps around the side so much it makes the side wall look smaller than it really is at 5"
  • 2 months later...
Another question please, is your vehicle stock height?, and do you have any "rubbing" issues when turning the steering wheel?
The reason I ask this is the people at Discount tire are telling me that the 305 tire on a 9.5" rim (stock offsett) is too wide and will rub in the fender well. They are recommending the 285 series, the same as the GM upgrade, or stock on the Escalade.
Thanks in advance.
