Air Raid MIT Problem
for some reason my air raid intake tube keeps coming loose from the throttle body? iv tighened it down several times and even switched the rubber ends to see if it would stay on better. any one else having problems with their tube staying on? if so how do yall keep it from coming off
No issues with mine. Cant say I did anything different to connect it
Havent had any trouble with mine either. Maybe try a little silicone around the connection.
Check the tube where it connects to the throttle body. If it is out of round or dented from over tightening it will cause this. I had a similar issue, fixed the lip of the tube where it connects and problem was solved.
^ like he said. Also make sure it's seated all the way and evenly on both sides I know a couple times I went to tighten down and it wasn't seated or overlapped all the way so if I had drove it would have popped off.
mine came loose once at the airbox connection.....it hasn't happened again for at least a month now...
dumb question, but are you sure you installed the right one for your model year truck? Because if you've tighted it a few times and still pops off then that would be where I'd start.
when I had the volant, if you connected the intake last, it would be hard to connect and even harder to keep connected. I ended up connecting the engine side first, then connect to air box. Did not come off again.
  • 3 years later...
I know this is a little late to respond to this topic, but I figured I would add this for future reference. This goes back to my days of turbo motors and intercooler pipes. A little trick to help the couplers to stay in place is spray some hair spray on the inside lip of the coupler and put it on. It will dry sticky and help it hold in place.
  • 2 months later...
I don't have this slipage problem but I do have a problem since installing an AirRaid intake tube. '13 Sierra SLE w/ 5.3.
I installed the Jr tube (running a K&N filter in the stock air box). Now under moderately hard acceleration or WOT, I get a loud, horrible sound like a vibration/grinding/rattle/howl from the passenger side under the hood. It's not the normal air groan/moan sound of the air intake when you get on the gas. (I've had cold-air intakes on several trucks.) This almost sounds like the K&N is jumping up and down rapidly or oscilating up and down or vibrating due to the volume of air going thru it. I had the K&N on the truck for more than a year with the stock air intake tube and never heard this racket. Everything is snug, nothing is loose. I don't see any visual problem with the K&N. Anybody have any ideas on what the noise could be coming from? I'm ready to put the stock intake tube back on. I'm new to this site and appreciate the help.
  • 1 year later...
I emailed air raid tech support since mine was falling off the throttle body once a month. They had me send a picture of the mit installed. They promptly sent a more flexible silicone coupler and I haven't had issues since.
    Camyon
    Camyon
  • Who's Online   5 Members, 1 Anonymous, 1,252 Guests (See full list)
