100k service - am I missing anything
I did a search first and didn't really come up with anything that was all-inclusive for the 100k service. I just wanted to make sure I wasn't missing anything.
Here's what I'm thinking/planning for my 100k service (see signature for truck):
Radiator flush, fill and new thermostat - let the dealership do it... to messy / disposal of old fluid
Transmission flush, filter and fill - let the delaership do it... equipement needed
Front differential drain and fill - amsoil severe gear
Rear differential drain and fill - amsoil severe gear
Transfer case drain and fill - GM autotrack 2 fluid
Spark plugs and wires - OEM plugs with Taylor 8.2 mm powervolt wires
Power steering fluid drain and refill with synthetic fluid
Serpentine belt replacement
Fuel filter
Clean air filter (AEM servicable filter)
I was also considering seafoaming it prior to changing the plugs and changing the oil.
Am I missing anything?
Thanks,
Chris
Sounds good. As noted above, brake fluid flush should be on the list. No worries on fuel filter, yours is in the tank. A few of the early flex-fuel models still had an external filter.
What about hoses? Ever been changed? Now would be a good time
The maintenance forum probabaly is a better location for this.
So the fuel filter is not serviceable without dropping the fuel tank?
Forgot about the brake fluid. Thanks.
Thanks all. Just a couple of additional questions...
I think the stock plugs are NGK's, but are they the platinum or iridium plugs?
Laser Platinum PTR5D-10
Laser Iridium IZTR5B11
If either one will work, what's the difference?
Also is there any reason to change out the O2 sensors if there are no codes? There are 4 of them (I think) and that's gotta be pricey.
Iridium was stock plug. Either will work. Iridium will last longer. I wouldn't touch the O2s until called for
stock plugs are AC Delco.
if the brake fluid hasn't been changed, now is a good time to do it. better left to a professional to bleed the brakes. or you could wait until the pads need to be replaced.
wouldn't hurt to replace the radiator and heater hoses while the coolant is out of the system. my bro's 04 z71 had a leaking heater hose the day he bought it and it overheated by the time he got home!
