CNG 2500HDs Coming in 2013!
I'm not savvy on this stuff, but I heard about this today so here's the link. Where would consumers get their CNG? I know some local mail trucks and buses use this stuff, but can the general public readily/easily buy it?
http://media.gm.com/...ifuel_silverado
Depends on your location I think. Around Toronto, there are 4 or 5 stations. There are 2 more in southwest Ontario. Approx 80 stations across Canada, but, they are in only 5 provinces. Our local gas company offers a home refilling "station". Good idea for comuting from the suburbs into the downtown core, but not good for going on vacation.
This is a dual fuel add on. It will run on gas and cng. Via selector valve and twin tanks. Effective range is over 650 miles with both.
Could be a good choice as you are not solely dependent on fuel stations
Havent they done this several times in the past? Or was it only available through aftermarket installation? I know my dad had an old 85 CC that was CNG.
So compressed natural gas. Does it burn as well as regular car gas . I know propane does not but it sure does burn clean propane on my dads old 91 f250 that thing can go over ever two gas tanks and a big propane tank in the back of the box.
its about time they started doing this! my company converts all our oilfield workers' trucks to CNG. only problem with some of the early aftermarket kits they installed was reliability. when the wiring got hot, the material becomes brittle and breaks. the offroad environment doesn't help either. Honda is currently the only company producing a CNG powered production vehicle. Ford and Chrysler are also in the works to produce a CNG truck.
i'm telling ya, CNG is probably going to replace gasoline as our main fuel source. there's a HUGE domestic supply for it, and the price of CNG is much less than gasoline. it also burns cleaner than gasoline. only problem is infrastructure. not many CNG stations around. here's more info on natural gas http://www.anga.us/ don't knock it until you understand it.
as far as performance, you get about the same horsepower out of it as you would regular unleaded. and much like regular unleaded, its not really recommended for high horsepower, high performance engines. more info on CNG http://e85.whipnet.net/yellow/cng.html
Propane and CNG burn cooler than gasoline. Gas engines use the expanding gases in the cylinder after combustion to actually drive the engine/vehicle. If the fuel burns cooler, you will not get the same power as gasoline, assuming equal amounts of fuel and air.
You can get a fairly good return on propane injection though. You can inject it on both gas and diesel engines, and see an increase in hp/torque of about 20-30%.
You can get numbers from this site.. http://www.propanecarbs.com/propane.html
Our local municipality has some Honda Civics that are CNG, we recently converted some dump trucks to CNG also. The only thing is there is only two local fueling stations.
I think that CNG vehicles would be a much better alternative to gasoline that ethanol. Granted, neither technology will net you the same fuel milage as gasoline for the same power output, but at least the cost of corn and corn based products might come back down to a reasonable price.
I hope they stick with it and give up these ideas of running ethanol and electrics. Electrics are great for small commuter cars that go short distances, but an electric pickup just cant be a good alternative.
agreed, not smart to use our food supply as fuel. the only thing natural gas is good for is burning it to produce energy
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
