I am having same issues with my crew cab. I think mine sounds more like a "ticking" noise. It will go tick,tick,tick then stop but happens the same way. Shifting into drive or reverse, turning and accelerating. Is there a TSB on this because it needs to go back to dealer before I tow my 33' travel trailer. Thanks for the thread on this, I tried to start one but no luck.
If it is the wheel bearings they are cover under your 5year/100,000 mile warranty. I just had mine replaced at 70,000 miles.
I can also look into this for anyone that needs more assistance. Please feel free to contact me privately with more detail and the last eight of your VIN and I will be able to look into this for you. Thank you in advance.
Tricia, GM Customer Service.
Try torque'n your front crossmember. That did it for my 08ext cab
Sent you my VIN
I have that exact same problem with my 2010 Silverado 4x4. I have checked everything but still havent found out why it pops just once. Its driving me crazy so i guess ill just start replacing things starting with the CV joints. If you have any luck, let me know.
My 08 Sierra did pop only when driving forward while making a left hand turn. Took her to the stealer they grease everything and it went away for a bit.
I take mine monday to the dealer, lets see if they can find and fix the noise. Any suggestions to tell them where to start looking? I will keep this topic posted on how I made out.
I am not saying this is the problem, not even sure if the gmt-900's have swaybar end link issues. My wife had an acadia that made a solid popping noise when making a hard turn at low speeds. It ended up being the swaybar end links, these were apparently a problem with these vehicles, as there were many discussions on it in a envoy forum I used to keep up with. I replaced them with ones that had grease fittings and never had a problem with it again. Hope this helps!
Edited by gm4ever
OK, dealer called and told me the drive shaft is where the noise is coming from. They have to order another one and install tomorrow. Dealer did tell me they had this same problem before. I will keep you posted.
  • 2 years later...
Had to leave a reply to revive this thread but I've searched all over the Internet to try and find out why there's a loud bang while reverse and Turning and clunky over bumps. The condition as many described here and it had me going crazy. I just picked up from my dealer and turns out it was a loose bolt on my front right caliper. With the loudness of the sounds I heard I thought for sure it was something serious but so relieved when they told me it was just a screw. Now rides perfectly. Hope this may help anyone else looking for a possible solution. Cheers. Car is a Yukon Denali.
Edited by highspeedvehicle
A loose bolt in a brake caliper IS serious, at least to me. Glad they found it before your caliper worked loose.
looking back at that comment yes a loose caliper is serious guess I was just happy it didn't cost a lot of money to fix lol:)
Definitely serious I just had a Yukon in last week that the bolts fell out and ripped the caliper off the hose. When it came in the shop the caliper was on the bottom of the rotor.
Sent from my LGLS990 using Tapatalk
    DM22
    DM22
  • Who's Online   6 Members, 0 Anonymous, 1,450 Guests (See full list)
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
    • I went to the county a few years back to dispute my property taxes. To do that I hired an appraiser and a lawyer. The County Assessor wished to argue that the homes in my neighborhood the appraiser used were all 'distressed properties" and not representative of the "Market Average".    My response was," Of the 50 homes in our subdivision 43 of them were "distressed properties" under bank foreclosure and as such "Distressed IS the market". Lawyer about choked on his coffee and handed the Assessor the 'receipts'.    I won that case on the evidence provided by the Lawyer and the Appraiser.    We have the same thing going on here. My statements were based on the GOVERNMENTS NATIONAL DATA and yours on local markets in areas of your interest. They are both correct....   Thing is, this divergence was based on NATIONAL and not on LOCAL. I think you even understand that. But like you said, we are both stubborn and hardheaded.    I do not see any advantage to disengagement.  But that said we can step back to compose ourselves.
    • Trust me I appreciate the comments and concerns. It's what I was looking for to help me evaluate the situation and what I want to do. I have decided to move forward with the BORA hubcentric slip on 3/8" (.375") with the extended lugs nuts. Fedex says they should be here Monday :). Meanwhile, the dealer got the remote start and Patriot spray in bed liner done over the last couple of days. Also, I installed an inline stop/start eliminator today. Starts back up in what whatever mode you shut it off in, so you don't have to hit the button every time you fire up.
    • $2.20 E-85 down from $2.59 Around $3.80 for regular and about $5 on average for Premium.  Propane $3.99 a gallon.
