I'm looking at getting an accord here soon unless some one can convince me otherwise
Sent while drinkin' a cold one...
Re-read your post
You have been convince :lol:
Ryan
Yeah man, it was going to get sold even before the wreck but it was/is so bitter sweet; Hell, the wife was in tears when I said it was officially gone. My very first truck I ever bought myself that hauled the family for 4 years. But, when I get back stateside, hopefully that diesel Colorado will be a proven family/tow monster that gets good gas mileage.
What car did you get man?
Re-read your post
Ryan
I guess I don't get it. I think the accords are slick looking, and it gets good gas mileage. Costs too much to fill up my truck with 93
The new Accord uses a CVT and therefore would drive like crap. Both the Malibu and Fusion are decent cars but the back seat is too small IMO. If I went with a sedan in that class right now it'd likely be the Passat.
I hate the fusions. Terrible options.
I do like the VW's. If I had to buy a small car it would be a Jetta or Impreza.
Oil change, rotated tires, greased front suspension, and found a power steering leak all over the under chassis and driver side suspension. Cleaned it up with purple power and need to figure out where it's coming from. Just replaced all my PS lines last year doing my hydro boost so I'm kinda pissed
And of course I would drive a couple different vehicles before I purchase but domestic vehicles with the options I want are like 33k+ which is why I kind of ruled them out
Edited by rdnckhntr94
I backed my truck and trailer through a maze
Cruze would be a good choice, diesel version would be pretty nice for some mpgs
Ryan
Too small IMO. Great small car, probably one of the best currently (and definitely ahead of the Civic and Corolla which is embarrassingly bad) but I want something big enough to be comfy.
I got a VW GTI; Extremely fun to drive and man will that thing get up and go! Getting really good mileage also.
Currently on my trip home from east side of state happy the roads are clear but unhappy with rookie truck drivers
sent from my truck in a field
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 636 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
