Keep dreaming they are designing them now so you have to bring them in for service it's all about money.. Sad world
Sent from a truck in a field
They already did, and it's called a GMT800. :lol: Takes me about 1 minute to change a bulb.
I worked on that Jetta today. Vacuum line going to the brakes had cracked a little. Fixed it and it ran a lot better. :D
And gmt400. They are very good trucks as well
Sent from my LG-D800 using Tapatalk
I liked my 1990 a lot, but to me the 2006 is easier. Oil filter is easier and headlights and signals are too. I'd rather change plugs on either of them than that Jetta though lol.
I went and picked up a tail light circuit board for a 95 silverado
Had to fix a leak on the 3rd brake light. Was getting in my truck at work and noticed water on the seat. Looked up and the headliner was wet right where the 3rd brake light. Took out the light and used black sealant where it sits on the cab. Hopefully it works!
Sent while drinkin' a cold one...
Tried out my new large gauge crimper just now. You use a hammer so I should do it while I'm angry lol but the thing works awesome. Got it for crimping terminal ends for my dual battery setup. Wire size is 1/0 gauge so this hammer style crimper is exactly what I needed. Only $20 shipped!
Tried pulling off the terminals and they are on their good. Way easier than sticking the terminal end in a vise lol
That's pretty neat
My driveway of GM for now. Last week in this house
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
