Two 10 minute segments is it. No way around that as far as I know. Depending on the frost it may not totally clear the window but even with the worst of the winter last year (-15F air temp, windchill almost -40) it got the heat plenty warm.
I guess it is better than nothing. She has heated seats, so she can at least be warm while she waits for the windows to clear up.
If you need to warm up for more than 10 minutes why not just use a block heater? 20 minutes seems excessive, but then again the coldest temp I've ever been in has been in the 20's. lol
And I finally washed my truck last night, along with dressing up the rubber, plastic, and tires as usual. Looking down at her from our second story office just got more enjoyable!
Hoping to hear from the adjuster today about the final verdict on my truck. Meanwhile all I can do is look at the pictures of the truck then and now.... :(
Block heater doesn't do anything for getting warm air into the cab, and it still takes a while to get the coolant warm. Unless it's extremely cold (-30 or less) I'd bet the electricity to run the heater costs more than the fuel to idle for a few minutes.
This was about a week ago... But I couldn't get past this sand section since my left wheel would just dig in. So much for off roading. lol
Edited by white1500
I wish there was cold and snow in Colorado
I mean this with all due respect. Dumb a**, (said in the Red Foreman tone from that 70's show) be careful what you wish for. :lol:
It has been sub zero wind chills in IL most of the week & cannot wait until this crap is gone.
Suppose to be 31(will wash truck) Sunday to get the salt off. But that 31 degree temp has
a ice/snow storm following it Sunday eve into Monday & the temps go right back down to single digits. :banghead:
My joke & thoughts of winter aside, this crash on I94 in MI has been on the news the past couple of hours.
Sad day for multiple families & in particular for the one life that was lost.
http://www.freep.com/story/news/local/michigan/2015/01/09/i-94-pileup-kalamazoo-county/21500281/
Edited by '01LS1
Gm has a decent on on the Cruze and aveo I think but I really like Chryslers black metallic.
Was reading the other day Chrysler/Ram is bringing it back on the trucks. The article mentioned they only switched to straight black
after the earthquake/tsunami in Japan a couple years ago. A major component of the color was either sourced or the tech was based there.
GM has it too. I think it's Granite Black Metallic or something. Saw it on a Caddy CTS-V at the GM display up at Ignace a couple years ago. In the sun the color was stunning.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,110 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
