Needs a bath
Ryan
I think that's the most dirt I've ever saw on that truck. [emoji1]
I gave up trying to keep mine clean around year 6. A black truck is ALWAYS dirty ... :lol:
Did a brake job on a '13 Subaru Outback today, and fed it some Amsoil. I like Subaru's engineering - they put these two M8 x 1.25 threaded holes opposite each other, plus a dimple in the end of the axle, so you can actually get a decent puller on the rusty rotors. Effortless removal! GM could learn a thing or 2 here. Also liked the normal pistons in the rear caliper - that's a catch 22, because the screw-in type pistons (aka VW) have a superior parking brake design.
Having a mini-drum with shoes for a parking brake seems totally ridiculous to me - why not just make the entire damn brake a DRUM brake? WTF. You'd think it would be cheaper, and keep the bean-counters happy. I gave up trying to understand automotive engineering around the '96 model year ....
At least that's one of a handful of things GM got right on my truck. DRUM rears.
Edited by Jsdirt
Looks like Ryan is mudding in Reverse.
Taking my truck to a shop today to get some advice right after I get my 2nd tattoo!
Great things happening (:
GM should give you a free truck for that milestone! :D
Exactly it was get out or sink
Ryan
Pulling a camper to Traverse City Michigan
Always confidence-inspiring to find this word printed on your driveshaft ...
Edited by Jsdirt
You better get some paint on that...
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 608 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
