Watched the mpgs continue to improve.
Same here. I've started driving mine on longer trips instead of the 2 miles one way to work and back. So far it's up to 14.5 from 12.9, and it's still climbing. The short trips really kill my mileage.
plasti-dip'd my front chrome grill. All black now.
Gotta figure what to do with my fog lights now. so annoyed. I've done cheap putco bulbs, hids, the current LED, and nothing seems to last more then half a dozen months. Would love Ridged setup, but I'd have to remortgage the house to afford it with the cdn dollar as it is lol.
That's probably the one thing I haven't had a problem with on my truck. Just OEM fogs, nothing fancy.
i wanted more light though. stockers worked until one went out. Then i went on this never ending quest for replacements and more light.
tempted https://www.theretrofitsource.com/complete-headlight-fog-light-housings/silverado-morimoto-xb-led-fogs.html?preselect=51272#.Vuv8alUrJaQ
or just go with some cheaper LED fogs again to replace the current ones. JDM Astars maybe.
It seems with these new lighting systems, you have to shell out some $$$ to get decent quality. I just upgraded a wall pack motion light here to LED - was over $100 just for the guts! All Cree LEDs, & the electronics were set in epoxy for waterproofing, so should last a while.
A few years back I converted our '86 Grand Marquis low beams to HID. Cost close to a few hundred, but I haven't had a single issue with them so far. This thing doesn't see winter or road salt, so that's a big factor too. Was pleased to see all German components, instead of Chinese. Guess you can't try to save a buck when it comes to these things.
so true. The current led lights I got from Hidguymodshop....and buddy has closed up. So no reply to my warranty request. Didnt think i was going cheap either.
Sorry I haven't contributed lately, my computer(s) have been messing up my account...let's see...
Oil change, oil and filter this time, still leaking a qt every 600 miles
Lubed the undercarriage, those grease fittings on the pitman/idler arm are so much easier to get to with no splash shield in the way...still looking to fab a shield out of a sheet of aluminum that I scrounged up.
Replaced passenger side hub bearing.
Finally located the clunk and click in driver's side front...need to replace axle shaft...has to wait until next pay day.
Located a replacement piece for across the front of the engine over top of the radiator. It was completely missing when I bought the truck. Went to a salvage yard and found one from a wrecked truck that was identical (to include paint color) to my truck. That one must have been diesel as there is a sticker on it that status "Max fuel tank quantity: 100 gallons".
Discovered where my blower fan issue is...for whatever reason as I would be driving along with AC on the air flow would slowly diminish and then no air flow. After cutting of the AC, and driving for a few more miles the air flow would come back to normal. So my AC is need of some serious maintenance. I think I'm going to leave that to a pro to figure that one out. I don't have the time, tools or experience to further diagnose the problem.
Now for what I've used the truck for and other maintenance.
Hauled 20 sheets of plywood to my shop from a local lumber yard.
Bought and brought home a mini bike to fix up (for fun) & continuing to work on my little Honda engine...we'll see if I can fit it in the frame of the bike
Changed oil in the wife's Jeep
Serviced my golf cart batteries, they were pretty low on water
Hauled a couple of nitrogen cylinder downtown down and back to a local place to be tested...heavy/bulky buggers
Went to Lowe's to get a replacement burner element for the stove...old one kind of got cooked due to we had a grease fire under the element...oops!
Replaced the overhead light in the stove
Hauled away a pile of scrap metal to my landlord's place for recycling
...and of course...
Had a few cups of coffee while driving to and from work
Had a few beers while shooting the bull with the neighbors
Think I'm all caught up... :driving:
Hit a bag the other day got sucked up thought the mail slot in the grille
Changed a fog light
Ryan
Those damn things usually end up on my exhaust ...
I always swerve to avoid bags on the road, they are a menace.
That was happening would have hit a wall or car. I knew he bag hit the front but didn't realize it got sucked in
Ryan
Edited by RyanbabZ71
Ah, that only looks a year old. :D
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
