I was gonna say. Mine looks new, but it's aluminum.
This was 2008 or early 2009 when i lived in Florida 30f50b4700a5fd8efeac0a7995b27862.jpg
I was always amazed at the vehicles I'd see on the road in Phoenix and SoCal. Stuff that rotted away in the northeast 30-50 years ago, still rolling with the original paint! Amazing how lack of moisture preserves metal.
Rubber is another story out that way, however ...
Yeah everyone that lives down the Cape has to deal with all that, on top of road salt. If they get 6 rust free years out of cars, they're doing good.
Finally finished the Mustang. Just needs a stepper motor for the speedometer. Modern gauges are absolute garbage these days. I took it apart thinking I could lube it, or clean it - still very difficult to move the needle by hand. Suppose I could swap the volt one with the speedo, just to get them by for now, but that'll probably fail soon too.
Sucks trying to upload anything here. I never have any problems with any other forums I'm on. Can't upload anything directly now - have to do it through Photobucket ...
Quality is horrendous - the smaller you can make it, the better it will look:
http://vid297.photobucket.com/albums/mm215/jjs05polaris/Forum%20pics/0319161259_zpsyo8i5lg1.mp4
I don't know of any forum that will host a video. And photo bucket kills quality so that's no surprise.
True all around. The best way to maintain quality and be easy is to upload to youtube and embed it here
Thanks, good to know.
Used to be able to upload pics here though - now they all fail to upload with no reason given.
size requirements for bandwidth.
Did that just change 2 days ago? That's when I started having problems.
No. We have had the size restrictions for a while
I haven't done anything different size-wise on my end. Even the small cell phone pics won't load. I don't know why that changed suddenly. Oh well.
Computers for ya! :nonod:
I appreciate your help, though.
Edited by Jsdirt
Haven't done anything to mine in the last week or so, but on Wednesday I plan to start working on replacing my torsion bar bushings, adding my leveling kit, and cleaning up/painting my frame from the back of the cab up.
Went wheeling for about 8 hours lots of mud under the truck had a blast883af5207cb85501968a258fdc7915aa.jpg
Sent from my SM-G925V using Tapatalk
Started the spring detailing since I didn't do it last year (concentrated on the car).
Clayed both bed sides polished and sealed. This is what happens with caked up mud when you polish
Finished
Ryan
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,317 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
