I didn't take it off cus of you and I didn't color match cus of you I'm going with red with black accents not full red
Had my tailgate handle/bezel painted by a member over on gmfullsize, turned out good IMO.
That looks good. I need to add that to my list.
And I thought I was like a Jedi. :nonod:
Mines tethered to the truck. Also never taken it to a full service station. Probably will avoid that at all costs. :lol:
That's also on my to do list. Looks good.
N.J only has Full Service. Its actually against the law here to pump your own Gas.
This one will
http://www.autozone.com/autozone/parts/CST-Fuel-Cap/2007-Chevrolet-Silverado-1500-2WD/_/N-jqi61Z8gcwh?itemIdentifier=867124_13324_5596_
Thanks Chris. Towed my boat 100 miles each way and never went over 165 degrees on the tranny. That Cooler you sold me does the job!
Then avoid Oregon at all costs
This one will
Against the law in Oregon as well.
I hit 200 easy with my big cooler towing the big trailer
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
While thankfully Jersey is small enough that you can blast through it on the turnpike on one tank of gas, though I can't say I'd have much reason to go anywhere near Jersey for non-business trips. Same goes for Oregon. I'd like to take a cross country trip some day but will not visit any states that don't honor my CPL.
So avoid the whole west coast, and NY and NJ
I pumped my own E85 today. $2.83 a gallon ($1 cheaper than regular)
Ryan
I pumped my own E85 today. $2.83 a gallon ($1 cheaper than regular) Ryan
cant find E85 in NJ, but I cant use it anyway.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,347 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
