They don't look right mine are es1000
Though I did get the ES9000, I am thinking that they left some hardware out cause I just looked at some images and there is suppose to be a bracket piece that slides through the bottom through the bushings so Monday, everything should get sorted out. hopefully.......
Clay bared and waxed the truck today
Noticed the black thing that's below the chrome front bumper is all scuffed up on both the passenger and drivers side. Wonder what the hell I hit.
Black Painted Door Handles?
Im interested to know how long the finish will hold up, being it gets alot of use. I like them alot!
Edited by BruceDeuce
Mine came painted and have held up okay so far. 47k miles and a little over two years old.
Same here except for a chip someone (valet?) put in last yr. they are very durable
Ryan
Yessir. Nice little ebay find.
Definitely makes a difference. I was wondering the other day about putting some on my truck.
Did a clean test on dash. Answer: not clean.
Sent from my Galaxy Nexus using Tapatalk 2
It makes an instant impact. Even with my truck being black. I say go for it. It's very easy and inexpensive to do.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,252 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
