It's pretty common to weld a bigger nut onto the manifold bolts to get them off.
The ones on my 1990 had never been off, all of them came out fine. Pretty funny since people break them on pickups with half the miles. :lol:
This is actually where the exhaust flange connects to the the manifold under the truck.
You know Zach, kids are gonna interfere with truck mods [emoji23]
Congratulations buddy!!
Sent while in 'Murica...
Haha paramedic school is doing that already anyway. Thanks man
Sent from my LG-D800 using Tapatalk
Roll coal braappp
I'd get that looked at asap....
It's factory lmao
Just installed a power converter in my truck. Attached it to my sub box. Should help with my friends that have iphones always needing to be charged lol
Has two house plugs as well as a USB port [emoji106]
Edited by rdnckhntr94
That doesn't make sense lol. Convert 12 volt to 110 and then back to 5? volt.
I would like a converter to run a fridge though lol.
Edited by kstruckcountry
It's for those pesky friends that always need their phone plugged in lol. I've had this inverter about 6 months and I've used it at the races and concerts to run a radio and it works great. 410 watts ain't much so I can't run anything big but for right now it will work. If need be I will upgrade to a bigger one in the future. I like how small this one is too. Fits right on the side of the box
Oh I gotcha. It's not often they are back there but when I got 5 people in the truck chances are half of them need to plug their phone in. Plus I will use it to charge my drills for work
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,207 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
