Today she hit 224,000!
And I cleaned her back up after yesterdays insane rain, I was expecting her to be very dirty but it wasn't bad at at all.
Although since we've had a lot of rain this summer I'm noticing more surface rust on the chassis. Even though its nothing compared to what trucks have in rainy or snowy regions.
And every time I drive her I appreciate the bilsteins! They're just such an improvement over the stockers.
Yes they actually make a significant difference. Riding in my friend's pickup almost identical to mine it seems like mine "shudders" a lot less than his.
Edited by kstruckcountry
Took mine out shooting both days this weekend. Used it as a bench to sight in my buddies rifle. Also broke out the kick ass AR style 22's, shot some skeet and finally got the .40 cal out as well. Must I say, it was an expensive weekend. Now, I have 5 days till bow season opens up here in VA. So pumped!!!
Sent while in 'Murica...
Is that and LT rated tire?
Glad you mentioned this because I just double checked. They gave us two P rated tires. The one that blew was a P. Reason I questioned it again is because we got a replacement tire and it was P rated so I checked the one still on the truck. They said they will replace both of them free of charge cause in their computer it recommended an LT rated tire. You just saved us $400 thanks!
No problem i was just curios myself. Makes more sense now though with how that tire failed.
Guys are stupid reds never let me down
Now be nice!!
I don't wanna get into it.. but let's just say I give/care too much and it has bitten me in the arse too many times
Sorry if that offended anyone lol
Edited by SarahsGMC
Sarah.. don't ever feel bad about giving and caring too much. It's a quality so many lack in this day and age and it is part of what makes you who you are and I don't think anyone here including myself would ever want that to change. It's when you find a special someone who also exhibits those same attributes of giving and caring that magic happens.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,012 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
