Truck now has USB charging. Kind of. Fitment is done. I need to do the wiring to the voltage regulators and the existing 12v wiring.
Edited by Chris
Went to a pumpkin festival
When I left the tires cleaned out nicely going down the road
Ryan
Ryan
Right in your wheelhouse?
Some but mostly on the road since it was dried by then
Ryan
What came stock?
What came stock?
Not factory from GM. USB in GM pickups didnt come about until around 2010. It may be on your aftermarket radio. Every aftermarket radio that has been in my truck, 3 different Pioneer units have all had USB.
Got my workbench delivered! (Gray in the corner) Got some nails in the walls to mount my extension cords, creeper, got my paint board up and started painting an old chain with some engine enamel thats been in storage for me for the last 2 years. :lol:
It's good to have a shop again!
I pulled the old sockets and put the newer GM USB sockets in
I checked the oil filter and plug because this morning I noticed a tiny oil stain on the ground as I was leaving (located exactly under the plug). And since I've been the only one who parks there in the last few months it had to be my truck.
Nothing is lose but the plug seems to have a tiny leak again even though its completely new. The old one also leaked a little, and this new one which matched the part number is even magnetic.
Looking like I need new tars soon:
Gonna see if my buddy, who works at a Ford commercial dealership (he's a diesel tech) can get me employee pricing for some toyo m/t tires. 37x13.5r17. Don't really wanna spend $1700 plus the cost of mount and balance for tires so closer to $1850 [emoji15]
Sent while in 'Murica...
Those ain't the problem, the pavement is chewing them up hahaha and no I do not do a lot of burnouts. Only done a few on these tires. 40k so far. I can get 50k
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,228 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
