Eh they have siping left, keep running em lol
Another piece of the puzzle got here today. Rotors on there have lots of life but I don't want to mess with turning them.
74042CA8-594C-4C99-849F-DCF68BF812E4_zps
Edited by kstruckcountry
I'm gonna run them till the wear bar unless during the first snowfall I have no traction. Rained earlier this evening and was leaving a friends house. Slid across two lanes, I think that is a combo of tires and the hard shifts from the tranny
Sent while in 'Murica...
I sanded down the bed and tailgate today
Got my Chrome trim, mirror caps and door handles on today!
Totally changes the look of the truck imo. (an improvement. Yall may not agree tho.)
Not a huge chrome guy but the accents look much better on the new trucks compared to the old where they seem clunky.
Chris, are you getting a bedliner?
Yes. I have it already. I had it for a while, but i was dealing with some health problems so i either had a lot of dr appts that made me too busy to do it or i felt like crap and didnt want to do it.
I did my weekly cleaning of the rims ceremony. Wouldn't have been bad but I didn't do it last week and they were all but black on the"dish".
With the new brakes you shouldnt need to clean them specifically ever again. I still give them a quick scrubbing but it's just for normal dirt, not brake dust like before.
My original alloy wheels were ruined by brake dust, they eventually began to get darker and darker until they were just fugly. Luckily we scored these gmt900 wheels in practically brand new condition!
Mine have a few spots of corrosion on them from the dust. I may try and recoat them someday. I may get a chance to put on the new hardware this weekend, we'll see.
Might as well scrap/sell those and get ones in better conditions imo. No need to spend $$$ on these wheels that are dime a dozen.
I really like the 6 spoke wheels though, they're a nice design. I'm sure eventually I'll get another set but refinishing this set would be a good project.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,000 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
