Sometime tomorrow I'm gonna do an oil change, rotate tires, and replace rear pads and rotors to see if I can rid the truck of my braking shake I get. Same thing happened in my other truck and that fixed it. New wheels and tires will be on order sometime this week, then it's going into the body shop to get the damage repaired from hitting two deer, get some paint touched up, couple dings repaired and my windshield replaced.
Also need to clay bar, compound, and wax it. Maybe body shop will do that for me lol
You dont have good luck with trucks.
Looks more like congrats Ford, two of their POS are on there. And I know I own one of them… I stupidly traded my very reliable 2014 Silverado, for what was suppose to be an economical 2015 Escape… It just the same MPG as the Silverado does and it's got the gas tank the same size of an 80 year old woman on a road trips bladder (gotta pull over every 400kms to fill up)…
Edited by Daly
Fixed some damage from my garage door incident
Before
After
Ryan
Reviewed my gas data for 2015
Total gallons: 1032
E85 Gallons: 1028
Total Miles 10,551
Avg MPG: 10
Avg Cost of E85: $1.89
Today filled up 19 gallons for $31. Not bad
I never keep track of that stuff. Way too painful to see on paper ...
I'm too lazy to total all that up. I log all my fill ups and repairs in a ledger. Once I even started to put it in Excel and then got bored after about 2 months worth I think. I know there are apps out there but still haven't gotten around to using those as then I'd have my written copy and digital. I'm pretty sure I used more than 1028 gallons doing a rough guess at 20 gallons for 52 weeks.
What's really painful is when you find your logs from 10+ years ago and see the prices you paid in high school.
Edited by Chevyguy85
Fuel log is a great one to use on Android
Can you do multiple vehicles?
Dont know. I only have 1.
Well as soon as I sell my '06 I'll have only one. I guess I don't have to log that one into the app. Just start doing the '09 instead then I could really see the cost of diesel.
*edit*
Reading the description in play store says multiple vehicles. I probably should have just done that to start. Maybe if I use it enough I'll just use my free credits on my google account and get the pro version.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   0 Members, 0 Anonymous, 1,299 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
