I have the paid version. Not sure what the difference is in the free version. For this all you do is enter your mileage and 2 of the variables32070dd37f58c928ef18c5277a74a4ba.jpg7e94e1984891b60ae474db24b8754f28.jpg
Additional Pro features:
* Unlimited cost entries
* Unlimited graphs
* Unlimited cars and vehicles
* Export functionality
* Import functionality (Overwrite or merge)
* Note field for text per fill up
* Adfree
I'm surprised that this seems to work on Marshmallow even though it hasn't been updated since July 2011
Chris, you need to charge your battery bro.
I will when i get in bed
They're about $40-$60 for a pair on eBay, so that's not too bad.
I need another pair - somehow my driver's rear got tucked up into the tire, and melted the thing halfway through. Must've backed into some packed snow last season. :nonod:
oh ok. They were $89 when I first looked at them.
How are they attached? Bolted on?
Yeah, mine came with self-tappers that had a ball of wax on each end to seal the hole up when tight. That was nice.
Had to drill a 1/8" pilot hole, then the self tappers cut the rest of the way in.
Sounds like a future rust spot but you haven't had any problems?
I'll probably put extra sealant on mine when I do it. Or maybe just blast some paint on the spots I can get to. I would imagine you can't get to the inside of the front fenders unless you can see through the door jam.
Edited by tranks
I only have them on the rear - none on the front. So far I haven't noticed any rust, and I drive some of the saltiest roads in the country. When I put them in, I made sure that wax covered both sides of the screw.
Within 2 years of rolling off the showroom floor, my truck looked like it was 15 years old underneath. Been keeping up with used motor oil or Fluid Film treatments the past 5 or 6 years now. Helps big time. It froze all the rust. Haven't seen any new spots form underneath in over 5 years.
Reviewed my gas data for 2015
Total gallons: 1032
E85 Gallons: 1028
Total Miles 10,551
Avg MPG: 10
Avg Cost of E85: $1.89
Today filled up 19 gallons for $31. Not bad
To compare
Total 93 octane: 668 gallons
Total miles: 8447
Ave mpg: 12.98
Ave cost/gal: $3.02
I'm too lazy to total all that up. I log all my fill ups and repairs in a ledger. Once I even started to put it in Excel and then got bored after about 2 months worth I think. I know there are apps out there but still haven't gotten around to using those as then I'd have my written copy and digital. I'm pretty sure I used more than 1028 gallons doing a rough guess at 20 gallons for 52 weeks.
What's really painful is when you find your logs from 10+ years ago and see the prices you paid in high school.
Where I'm at, I AM paying the prices I paid 12 year ago. Reg is 1.49 a gallon right now.
When I started driving 96ish $1.04 was the cheapest I ever paid
Ryan
I remember heating oil at .60 cents a gallon, and gas at .74 - cheapest I ever paid was .88 cents a gallon.
Sure got alot more bang for your buck in those days, especially with cars, trucks, and outdoor power equipment.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,207 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
