I always found the green can to work better for me - seemed like the red can stuff never evaporated. The green can evaporates pretty fast.
Lmao here in Michigan we blow CFCs all over the place
Sent from my SM-G925V using Tapatalk
We need to turn Chris in. Probably get more jail time than a murderer lol
  • Like 4
Legally bought in CA. Not sure whats different from the good stuff but i miss it
The good stuff was so strong, it would peel paint and soften plastic ON CONTACT. Had to be real careful of overspray. Just made the job 10x FASTER than the watered down crap we get today.
The old stuff also just about blinded you when you got it in your eyes too - this stuff barely even burns by comparison. :D
Picked up some items
I didn't know those things were still for sale. Haven't seen one in well over a decade.
Sounds like you have been experimenting lately.
Sent from my SM-G900P using Tapatalk
No - I just have decades of experience with the stuff. When the formulation started to change around '08 or '09, it was a drastic difference. Required MUCH more effort to do the same job ... and the crap costs the same ...
Not like the old schwinn ones you remember, much newer company with revised systems...they still suck as bad though for a workout...I would rather be on a rower any day
Edited by nbobinger
I'm at 85,109. Just 4-wheeled up into a neighbor's field with the wifey, to watch statewide fireworks as the ball dropped.
Best view on the planet from over there. A billion stars at night too, when it's clear. Didn't see to much. Saw the flashes in the clouds from Hartford's display, and a couple local private blasts someone shot off a few towns over. Still fun though. Me and the wife still feel like teenagers. :)
Here's the spot in daylight:
I replaced my AC belt tensioner/idler, it was pretty worn. I need to do the main belt idler and tensioner soon.
Under the truck, I noticed the left hand seal on the front diff is leaking like a sieve. NOT excited about that. Still full of oil, but visibly wet where the CV bolts up.
Sent from my SM-G920V using Tapatalk
I replaced the right upstream sensor on the 5.3 in my brother's Rainier. Pain in the ass. The 2 month old Bosch sensor was causing a lean bank 2. Put in a new Denso and all is good
Mine started doing that at 45k! Now both sides do it. I gave up caring a long time ago.
Reminds me that I should probably see if there's any lube left in there, since I've never checked it since I put it in ...
GM quality! :nonod: Pic was taken in '12 ...
Edited by Jsdirt
    • I know; crap pictures.   Anyway, as a finale of sorts to this thread, I had replaced both differential covers and since they had the capability of adding temperature probes, I did that. These are MaxTow analog/digital gauges with stepper motors. They'll flutter around like crazy for a moment and start at a nominal 100 degrees Fahrenheit.   I drove a 30-mile loop to the grocery store, averaging 70 MPH (as much as 80 to see if there was a quick spike in temperature. The air temperature is 102 (ambient ?). but the first pic is 7 miles into the trip. The second is getting back into the truck after leaving the store; differential temperatures dropped about three to four degrees in 15 minutes. The third pic in on the road to my house, about a mile away.   In that run, I saw a high of 150F on the rear differential, and 121F on the front. I'm sure a longer drive or towing will see higher than that, and when that happens, I can update the observations.
    • You don't want to become predictable now, do you? 😏
    • Fully warm, coolant temp >194, closed loop.   Run time can be anywhere from just reached operating temperature to having driven 30+ miles.   The O2 chart (which is a feature I just discovered after reading) for the bad idle seems to be "most" of the time. For the little time I've been watching it (scanning and driving! watchout!) I can't seem to isolate any cause or condition yet.   It definitely idles rougher sometimes than others and so far what I've seen is the rougher idles are always rich. But not enough to set a CEL.   In other news I replaced the starter solenoid. Everything on this truck is such a PITA. Starter "snout" is mangled up with the torque converter inspection cover which is tangled up with hard cooling lines and the driveshaft. But I got 'er done without too much swearing...I just go into everything now knowing it's going to be a frustrating mess.   The starter solenoid replacement kicks off the next round of work: AC, injector rebuild, cat, exhaust. I'm just going to do it all. But first:   I don't know what my fuel pressures are. I can't definitively say the issue is the injector without first verifying fuel pressures and any leakdown. I "rented" a test kit ($199.99 at O'Really's ...intentional misspelling). They don't "rent" tools anymore, they charge you for the tool and then you return it when you're done. No joke. It is listed as a rental on the receipt but the guy told me there's no difference between renting and buying  now, you just return it when you're done and they refund the credit card. Mmmkay, whatever.   I will rule out fuel pressure issues (too much), and any leaking (that's how I'll know the problem is inside the intake). I think someone said the return line could be plugged or not flowing and that could cause high fuel pressure (and too much fuel being pushed through injectors). I'll cross that bridge if I get high readings.   As of now I'm ready to tear off the intake cover, extract the injector, and have it sent off to be rebuilt just so I can rule that out.
    • What are the conditions of this rich idle? Warm or cold engine? Run time? Does every idle look like this or only sometimes?
