Hey guys,
Just thought I would put out an introduction post to say hi. I just started making some mods to my truck and now I have some katzkin and an OGM-1 on order. I'm pretty excited.
This making mods and buying accessories thing is like a bad addiction. And you guys aren't helping!!! LOL
Anyway hope to talk to you guys soon.
