new Rough Country leveling kit option
Wow. I had not seen that yet either. I would probably have done this if I it had been available. I still like the cast iron rear block that the ReadyLift has available though...
thats funny i thought about making some thick washers on top to make a spacer just like that lol. i already have RC 2" lever they should sell just the top spacer and rear block as a kit also
Im about to add 20x9s with 5" Bs so will give me extra security with the rubbing. Going to run 305/50r20's
they JUST came out with that, got the email at work last week or so. and agreed i'm not so hot on the rear block option they have...
sic lx, i have 20x9 novakanes with a 295/55r20. it took me a 2" rough country plus a 1.5" zone body lift and trimming behind the fender liners and then pulling them back with zip ties to clear...
there are other 2.5" leveling kits out there, so i dont think this one will be terrible. they should sell just the top spacers seperately, and use better rear blocks.
I sent RC an email today asking if they would sell just the top spacer and/or rear blocks, since a lot of people already have the 2" level. No reply yet...but will keep you guys posted.
i did the same thing! i want the top plate and the rear block!
ruggedlife
Im just going to run 305/55r20 for now with fuel boost wheels with 0 offset
rear blocks didnt think their would be much to them. what they say about them This kit includes a set of Fabricated 2" Rear Blocks to replace the OEM 1" block. Fabricated blocks offer a longer lifespan than cast blocks and are less susceptible to damage and the environment
  • 1 month later...
ruggedlife
Because somehow a larger tire will fit with fewer mods?
I had the RC 2'' levelling kit on my last truck with 3'' rear blocks. I'll likely put the 2'' blocks on, but i'm not sure if it is enough in the back. I hate the 'level' look.
ruggedlife
meant 305/50r20 already got them now saving for wheels
My buddy has this lift on his 08. Works great and he loves it, he also put the 2" block on top of the factory block. His trucks got a lifted but still raked look. Looks awesome and works great.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
