front end "clunk"
Hey guys i need some input here. I have a NBS '07 Sierra 4x4 crew cab. I've been noticing the last little while a "clunk" which seems to be coming more from the pass side. I only seem to notice it when i'm turn at slow speed and going over a curb into a parking lot. I've checked the body mounts, step bar bolts, shock bolts, sway bar bolts. Any ideas???
maybe the cab mount ? there is isolator bushings for them to stop the noise, they are just thin teflon washers that go between the mount and the cab
mine where tight also but these took the noise away, there is a long thread here on them along with a description of exactly what you describe in symptoms , I think they where like $ 3.00 each
I'll see if I can find the post on it
I have that clunk sound and it is a bushing on the steering shaft. I haven't changed out the part yet. I have an '07 GMT900 and this noise started at around 30k miles and continues to this day at 57k miles.
