Katzkin ordering help
Ordering from shopsar.com I picked my colors, just going with the stock look nothing fancy. but I am answering the questions. The ones that get me are about the seat size.
I indicated that they are 40/20/40. Now I have the option of 40/20/20 with center armrest or 40/20/40 without center armrest. Which is it?
Also is the back seat cushion considered solid? I believe it is since it does not split, but the headrests are separate and the bottom folds up.
Interior is not my strong suit. Thanks in advance for the help
Well what type of seats do you have in the front? I would order mine with center armrest I think since I have the split 40 20 40 seats with the center console/armrest.
I had the 40/20/40 with the folding center seat. I took the center seat out but I don't know if the center armrest means jump seat or the armrest built in the buckets
  • 1 month later...
No not yet. I backed out on that for now and got my MBRP exhaust instead and funded a vacation in Utah. It's on my to do list but not high. With traveling the MBRP was needed. The Flowmaster wasn't great for long drives
Good move.....I just did my 2010 in Katzkin Black. When you are in the market again, check ebay. Got mine for $550.00 shipped for an extended cab. Much cheaper than anywhere else. Got them form "seats-r-us" I believe.
Now I ordered a $500 alternator and ordering 15 ft of 1/0 cable tonight. Need that for the stereo. I think 3.73's and a TruTrac to replace my open 3.42 is next
Sent from my DROID RAZR using Xparent Red Tapatalk 2
4.10's would make that 4.8L feel like a entitely different truck. Had those gears in my 2000 ZR2 blazer with a 4.3L and it was impressive.
It may be worth the extra $ since you only have to do the rear end. Take a look at the G80 also, unless you already have your mind made up.
Sent from my iPhone4S
using Tapatalk
I can't find a new G80 and hard to find a used unless I find a 9.5 or 10.5 whatever the 2500's have. And I drive probably 65-70% highway. At least 250-300 miles a week on the highway.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
