My thoughts on 2011 F-150 Ecoboost
doverarjim
My impressions of a 2011 F150 ecoboost. Had this as a rental while my truck was in the body shop. Drove it just like my 2500 every day, same roads doing some of the same stuff (would not have liked to tow with it) The ecoboost was zippy, mash the go pedal and it would jump from 1500 rpms to 6500 rpms right now and it would move out pretty fast, pulled onto the interstate and got to 85 mph in the accleration lane. Some buttons were hard for me and my big fat fingers to work, i.e. cruise control was a pain as was the a/c and radio controls.
Fuel economy was the real suprise came from, back and forth to work 10 miles at 60 mph to 65 mph and then 5 stop lights in 3 miles Ford got 17.5 Mpg, I hauled off a bed load of junk took about 20 minutes to load 500 to 750 pounds at most got 15.1 mpg. My truck makes the same trip at 16.8 mpg and when I have a bed load it is over 1000 pounds and I still get 16.5 mpg.
Sorry this got so long just wanted to tell my thoughts. :jester:
  • Replies 75
I'm glad to hear real world thoughts of the Ecoboost engine. I've got the fat finger problem myself so I can imagine the "joy" it must have been with little buttons. Fuel mileage definitely seems to be the big debate I've been hearing the most about. Some say good, some say, not so much. I think the concept of the ecoboost is valid but still a few years worth of bugs to work out before I'd consider one, in my opinion. Still glad to hear you getting your truck back.
I think for a truck they should put the turbo on the 5.0............ then there would be no debate, everyone would want one! Ford is heading in the right direction with this concept- just need a little "nudge" to give us an ecoboost V8.
That's my problem with it too, it will never be a "truck" because it's a glorified car motor. It revs right out. Interesting to see the mpg results tho.
I bet that EB motor makes more toque at 2000 rpm than anything GM has aside from the Duramax. Calling it a car motor is stupid, just because it showed up first in cars doesn't make it a car motor, same as our trucks since the V8s showed up in the Vette and F body initially. If anything the cars are just proofs of concept for the trucks which both brands make their living from.
My ecoboost was a nice truck overall. Too bad I, and many others, had some safety engine "quirks" that ford couldn't and still can't figure out.
Sent from the Blackberry Bold 9900 using Tapatalk
Some more things to add, I thought that there was a can of spray paint it in the way it rattled! I have a gravel drive way and that thing would just about shake you out of the cab. Also it looked like they forgot to put any bolts in the bed to keep it on the frame. It bouced around a lot going down the drive way, That was the one thing I feared most about having my truck taken so far apart is that it would rattle after the repairs, but so far no problems.
I'm sure as I think of more things I will post them here. :jester:
Funny you said that. Mine was a fx4 and the bed bounced like crazy. The frame was so stiff that you could see bed bounce in the sideview mirror
Yeah..............so...........Imagine a 5.0 Eco-Boost! And a larger displacement Eco-Boost for the Super-Duty. GM & RAM would have some catching up to do.
I'd love to see a turbo V8 but it'll be a gas hog and you simply can't have those now.
the ride and build quality was the biggest factor in me getting a gmc a few years ago when I got back in a truck. drove an F-150 xlt cc and a Sierra cc back to back and the ride was so much better in the the Sierra. I loved all the room in the Ford but I know I made the right decision to come back to GM.
There's no way it would be a gas hog. I bet it would be better on fuel than the V6 or anyone else's V8.................and way more power than any current model you can buy today. Look what a turbo did for diesels- remember when diesels couldn't get out of their own way because they couldn't make any horsepower. Well think of what one could do for a gas engine!
Doesn't make it a v8...sorry.
Yep! I agree. I think what Chevyboy is saying Mike is the V6 is just not enough displacement for a big truck- great for the Taurus though.
    whenindoubtuseahammer
  • Who's Online   1 Member, 0 Anonymous, 366 Guests (See full list)
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
