Front Wheel Speed Sensor Harness?
SSSilverado23
I have an 06 Silverado that has a bad front wheel speed sensor harness. Its not the speed sensor in the hub itself. Its the actual harness/plug on the other side. How could i replace or find the plug for that? If you buy a wheel speed sensor you get one side of that plug but i cant find or dont know what that other side of the plug is called? Help would be much appreciated! Thanks.
I'd think a dealer should be able to pull up a diagram of the part. That way you should be able to get a nomenclature and/or part number. I personally don't know what that part would be called either, sorry.
i think he means truck harness end not WSS end.
he will need the terminals for the connector end ,i think they come empty...
he may as well make his own connector
Ya i need the other end not the WSS end. I got a guy at autozone that said he thinks he found it and ordered it for me to come look at when it comes in. Hopefully he got it. Said it was under windshield washer pump connector/pigtail.
