Tire Cupping Question
tyhuck
I have noticed some tire cupping on the front tires of my truck. I went to get them ballanced and the tire tech said that the cupping is caused by being on the rear axel, so he recomended not having them rotated. I didnt feel that this was right, but I wasnt sure. The rear tires seem to be pretty evenly worn. The problem is, I bought the tires second-hand and they were cupping already, so I cant tell if they have gotten worse on my truck or not.
Would it be worth the extra money to have them rotated, or was the tech correct about the rear axel causing the cupping?
Once cups they will only keep cuping
Sent from my ADR6400L using Tapatalk 2
I think the tech doesn't have a clue what he's talking about. Cupping is usually caused by the front end being out of alignment. I've never heard of tires getting cupped from being on the rear of a live axle vehicle.
But if the tires do get cupped and you rotate them to the back, then back to the front, they'll probably keep cupping.
An alignment is well worth the money.
Had the truck alligned not to long ago, so it should still be in spec. Im gonna go ahead and have them rotated and see what happens. Like I said, they were cupped when I bought them.
Well, I rotated them myself this morning, so hopesfully that will wear the ones that are cupped badly a little more evenly. I know I will need new tires eventually, and that even wear on a 35 is almost impossible. I have accepted that. I just wanted to confirm that my assumption of the tire tech being wrong. Ive always heard that it was the front wheels (or rear with IRS) would be the ones to cup, since a live axel doesnt allow much movement unless your shocks are worn out.
I spent $60 to have them road-force balanced, and they shimmy worse than they did before. Gonna try to get back today and have them fix it. But, I know one thing, after they get it right (and they will or they will give me a refund, trust me) I wont be a repeat customer. Unless of course, this visit is a world of difference. $60 for a ballance is just too much for me though.
buy your tires at costco I believe they rotate and balance them for free if I remember correctly would have to look at the paper i have.
Most shops around here will do that as well, but I bought these second-hand. I wanted 35s and these were the right price. Plus, they bought me a few more months without dropping the $1500 for a new set. But, I probably wont go the used tire route unless a deal like that comes back around.
rear axle causeing your tires to cup? no thats pure BS. the only reason your tires cupped is because they were or are out of alignment. you need a good alignment shop to give you an alignment and see where it goes from there. also its going to be very very hard to tell if your tires are cupping if they are already heavily cupped. i would just buy new tires and get it aligned with new tires and then watch how they wear closesly.
also, i know many people who have put steelies on fullsize truck and had nothing but issues. i know a few people with steelies and after a certain amount of miles or usage they get out of round and will obviously cause a vibration or shake or shimmy, also steelies are also easier to bend if you do moderate offroading, so as for your shimmy i would try and find a set of steelies to borrow and throw them on and see if it shakes or anything.
i could be wrong, i could be right, who knows, but that is just what i have heard and seen from my experiences with steelies
You can get cupping from a bad shock in the front as well you guys. Pretty sure. Once tires are cupped only thing you can do try fix the cause and put the cupped tires on the back....
Cupping is usually an alignment issue or bad ball joints tho..
I would put them on the rear and then do a brakestand until you can't see out the windshield anymore from the smoke, that might get rid of the cupping. If it doesn't it will still be a great video to share with us. :thumbs:
That also might work ahah
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
    • Very often the part number on the trim part is just for the vendor order/assembly plant and will not show up in the parts system.  They won't make a bunch of extra parts that were not ordered. Keep in mind, lots of these parts were made to be "just in time" parts meaning they were dedicated to a vehicles ordered and sequenced for assembly.       Also, trim parts will often say, paint to match.
