8.1 Re-build... Need Some Input
Just curious, but what is your goal for use of the truck? You already have the one with the raylar cam and tuned up with more work planned...other than doing something similar with a diesel instead, is there a difference in your intended use? Or are you planning on selling the gas truck when the diesel gets built up?
No i love the white sierra.. Thats a keeper, I was going to just build the 8.1 and make a fast toy truck but still will use it fordoing stuff, If i put a diesel in this cc lb fully loaded silverado it will be the family truck and
be able to pull any camper we get comfortably while getting 12-15mpg..
Before this truck popped up, I was looking into a mega cab cummins
Simple. Lift pump, CAI, str8 pipe and dsp5 switch. I can hook you up with some very reputable tuners and good prices!! Doesn't take much to get 450-500...you could do in a tune alone but I wouldn't recommend it without a lift pump and some sort of exhaust. Most guys with stock tranny shoot for 450-480...after that your tranny is playin with fire.
edit: just realized you have a 5 speed, i wouldnt go past 450 without a shift kit in a 5 speed.
How do you feel about the banks kits/products? I was looking at a banks 6 gun set-up.
Stacks, roll coal, and ALWAYS drive with tow mirrors extended
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
On the cummins that's good for 90whp
Don't do it. Call ATP trucks, or TPT trucks. Use kory Willis or rob coddens. banks is expensive for a canned tuner for little gain.
Cummins are awesome if you can spend the $$$$. They need hard parts to make powa tho, duramax can net over 500rwhp safely with little upgrade.
Gotcha.. Ill get it installed and then worry about the details i guess, $3500 seemed like a good deal ecspeccially
for an lbz, I had two lly trucks and wasnt impressed.
LOL you guys are funny..Stacks...tow mirrors, And NO im not doing stacks!
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
    • I'll bet your truck lost the bearings on a roller on 1 of the lifters, and now is wiping out a cam lobe.
