BDS or Rancho 4"
Well guys, I've changed my mind again. My plans was gonna go with a 3" Body Lift. Also, going with the 33" Toyo MT's. But I just bought some N-Fab steps that a price I could not pass up & also Recon Smoked Tail Lights.
The guy I bought the side steps from was like you should do a 4" Suspension Lift, instead of a BL.
I was like yeah that sounds good, but just the money. I could do this save up like 2-5 paychecks & I can do this. That would look so wicked! Especially with the Steps & Tails already being ordered, (Both will be here at the end of the week).
So guys, my question is should I do the SL or stick to the BL?
If I got the SL, I was gonna go with BDS or Rancho. 4". I would do the 6", but I think 33s with a 6" SL, wheels & tires would look to small. I know most of yall will say do the 6", I think the BDS 6" cost like $15 more than their 4". Rancho sells their 4" at like $1,464 with Free Shipping.
BDS sells their 4" at $1,802.
I'm sticking with 33" tires, Toyo MT's.
I can't afford doing 35's & having to regear.
Using the same rims as I have now. XD Spys Black.
If you have the money to do a SL then I say do it. Just remember to factor in the money to have a shop do it or read through the lift instructions to see how you feel about doing it. I've done my own BL and helped a buddy do his, they are no big deal to do with simple tools in the shop or in the driveway. I've never done a SL but my buddy said his BDS on his HD was kind of a pain in the ass and he did it on a lift in our friend's garage. He said it was a pain dropping the diff, exhaust seemed to be in the way at times, shaving cooling fins, cutting chunks out. Really he said it was more nerve racking than hard, just said he didn't want to do it again for a few years.
Long story short, I vote SL if you have the money and feel like you can tackle it in the driveway. If not then figure 500-750 for install, not sure what your rates are like out there.
BDS all the way. Much better kit and customer service is second to none.
A much better kit? I wouldn't say much better, in fact I would say equal.
The Rancho kit has a one piece sub-frame, which is superior to any multiple piece sub frame. Rancho has adjustable shocks, BDS doesn't. BDS has a fox racing coil-over kit, but it's a $4,000 kit by the time you add in all the extras.
Rancho is an OEM supplier to GM. The chances of having warranty work declined because of a Rancho lift are much less likely because of this.
The BDS 4 inch kit, is just that, 4 inches. It sits too low for 33 inch tires IMO. The Rancho kit offers 5 to 5 1/2'' inches of lift, it is the perfect stance.
Track width. Rancho has 1/4'' less track width increase per side. I know that amounts to only half an inch overall, but I for one despise track width increase, so every little bit counts.
Overall, the perfect stance of the Rancho is what persuaded me to go with Rancho over the BDS kit. The 6 inch BDS is too tall for 33's, it looks goofy. The 4 inch isn't enough.
What LazerBlueZ71 said. While the quality of both is second to none, I think the look you are going after would be best achieved with the Rancho "4-inch" setup.
Well, I thought I heard one time the Rancho 4" was like more of a 5". I just want a near perfect stance with 33's.
I don't think my wheels would stick out too much, they're about flushed with the body line now.
Doesn't BDS come with a lifetime warranty?
What shocks should I go with, if I go with the Rancho?
http://4wheelonline.com/Rancho_2007-2011_Chevy_Silverado_1500_Suspension_Lifts.43721.0
Laser blue is on the money. BDS takes the nod in the warranty department but Rancho is a solid and taller kit. I personally would go the 6" route though. I have seen dozens of dealership outfitted trucks running Fabtech (8") with 33x12.50s on 10" wides, and it looked good. The reason they did this is to avoid any and all rubbing because, you guessed it, 35s on 10" wides will rub. I used to run 5" of lift and my 33s rubbed a little with a conservative wheel. I would've much preferred having 6" at the time.
http://4wheelonline....n_Lifts.43721.0
The Rancho nets you about 5 1/2" of level lift. I have the Rancho RS9000XL adjustable shocks (which were a small upgrade over standard) and like them pretty much. Might go with Bilstein 5100s the next time around just to try something different. The Rancho kit also holds a limited lifetime warranty. I had 33's on stock 17's / stock offset forever until upgrading to 35's over the Fall. I did put 1.5" BORA spacers on the rear to even out the rear stance to match the front (which you will have to do with just about any kit). The combo with 33's looked great.
Well guys its the BDS 6" or the Rancho 4".
I'm really now having a hard time which one I rather have.
Another happy Rancho customer here, no problems with anything in over two years. The BDS is solid too though, either way you will be happy IMO. I believe your wheels are +18 offset, I ran 33's and the same offset wheel and it looked killer.
Here is another point for Rancho. It allows the use of stock wheels if you ever need to go back to those, the BDS kit doesn't.
I know most of yall, won't approve this.
But the 5" RCX isn't too expensive, $999,right now.
& go with Bilstein shocks?
Suggestions?
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
