GM-Trucks.com Member Map
Josh
  • Replies 50
Pinned. Don't care who knows who knows what town.
As the saying goes, "We don't dial 911".
I claim the entire west coast!!!
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
You can have it too.
I guess I can't do the map from tapa so I'll have to remember to use a browser and mark Orlando.
Sent from hp touchdroid
I claim the entire west coast!!! Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
I'd claim Iowa but I'm not sure if anybody else really wants it. :dunno:
Don't make me invade Iowa Jon
Pinned! First one in North Dakota!
    zibzer2
    zibzer2
  • Who's Online   4 Members, 0 Anonymous, 739 Guests (See full list)
