I would have to go find the letter and see what it said, I was sure it was recall but went and found it. It does not indicate what it is in the letter, just additional vibration might occur (among other symptoms) and to come in and have it checked. I feel cheated, they are not even calling it a campaign. Perhaps I should write a letter to GM complaining...
The letter says, "... so we are announcing a program to prevent this condition or, if it has occurred, to fix it."
GMC is calling it a program which sounds like lawyer speak that they need to take care of it without admitting too much liability.
When did you get this letter from GM? I have a 2011 Silverado 2500HD and I haven't seen anything yet.
Edited by spitfire
Thanks for the help guys. In the mean time I spoke with my buddy who owns a trans shop. He told me its probably the G80 acting up after being on the highway for a long period of time, and the oil thinning out from heat.
We will see what GM says.
Thanks
??? What??? That doesn't make any sense in my mind. I drove from Alaska to Georgia on a 6300 mile trek with my truck with 50k miles at the time. Original oil in the rear end and the truck was fully loaded (and towing) and driving for 12-14 hours a day. Never had a vibration that came from the rear end. I didn't even change to oil for the first time until about 96k miles and it was still pretty good looking at the time. I personally would want a second opinion of that assessment. No disrespect to your buddy but that sounds a little "off" to me.
There is a recall on the 2011 2500HDs regarding the rear end. Make sure they check that while you have it there.
I can also look into this for you as well if it is a recall with the last eight of your VIN. Contact me privately for more assistance. Thank you.
Tricia, GM Customer Service.
May 2012, and I'm glad this came up, I need to find some time and get it scheduled.
Well dealer had it all day today and just got a call that surprisingly he didn't feel it. I'm sooooo surprised. Going to pick it up tonight and go back down there when I have time for him to go for a ride with me. Funny thing is I felt it happen in the parking lot when I dropped it off.
Matt
Edited by mattymax
Went for a ride today with a friend of mine who knows a good deal about vehicles.
I couldnt get the truck to make the noise/griding unless I drove on the highway and heated up whatever is going bad. Came off an exit and slowly strarted off from a stop on a slight incline with the wheel turned right and it happened.
He beleives the passenger side caliper might be hanging up after the heat get to it. Its more described as a grinding, chatter kind of noise. Once it does it the first time, it does not do it after until you repeat the drive.
Edited by mattymax
  • 8 years later...
On 3/26/2013 at 3:28 PM, mattymax said:
Dealer thinks its in the rear
Went for a ride with the tech today and we were able to reproduce it twice.
Goes in Monday
Matt
So what ended up being the problem & solution?
    • No ETA is available for that engine at the moment in the GM system.   I would start at the dealer.  Try and talk to the parts manager or service manager and see if they can start a CX Connect case and get an ETA from GM on when engines may be available.  If they just check Parts Workbench and say "no eta", they aren't trying hard enough.  They need to do a CX Connect and chat with DPAC to find the ETA.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
    • We had two Toyota’s with that engine in the mid 80s. We had 50 gallon fuel tanks, a toolbox full of tools, an air compressor and assorted parts for our equipment. We beat those up and down pipeline ROWs until we started buying diesel trucks. Then they became parts runners and first vehicles for our teenagers first cars. Our shop Forman wrecked them both two years apart when we hired him out of high school as an apprentice. Good thing he’s an excellent mechanic. It took awhile before he could be called a good driver.
