Tranny over heating while towing
The answer to the 2nd question is no, he didn't have an aux. cooler from the start
  • Replies 235
Im in the same boat! If Im a little aggressive my temp goes up to 110F.
That's it, 110? I wish mine ran that cool. Mine is normally 80 degrees above ambient and 100 degrees above ambient while towing
Yeah 110 would be nice!!! I looked at your write up on the Trans cooler nice job! I noticed your lines are pointing downward, I assume it makes no difference?
I kept it that way for two reasons: 1) to keep the minimum amount of rubber hose, and 2) the stock lines are like that, so figured they did it for a reason.
Reason I don't like a lot of rubber hose (aftermarket hose) is because I had one blow up on me and cost me a new tranny
Ya it stays around 200-210 while towing. And I do have a cooler I really just want a replacement one that will bolt on and keep it few deg cooler
My lines are coming from the bottom not the top. I didnt have a cooler from the factory. I will be getting a new cooler at some point. The one I am looking at is larger, and utilizes AN fittings
Are you currently using B&M 70268 SuperCooler Automatic Transmission Cooler?
Yes I am. I may be going bigger though
You have that big 6.0! I think B&M 70268 SuperCooler Automatic Transmission Cooler will be adaquate for my 4.3, what you say?
I have the same one on my 5.3L
And it works good? Or should I go with something bigger?
    JohnRoy
    JohnRoy
  • Who's Online   5 Members, 0 Anonymous, 646 Guests (See full list)
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
