BFG All Terrain or Trail grapplers?
BrannonP
Hey I'm new here and was looking on some advice from someone more experienced on which tires I should get.
This is how my truck looks now. Just put on a 2" RC level and probably won't do much else suspension wise.
Now I have 285/70/17 Terra grapplers and they're getting worn so I was looking at getting 285/70/17 BFG AT's or trial graps. I was looking for a tire that performed a little better off-road and I like the look of both the bfg's and trails. Has anyone had both of these tires in a similar size and can offer any advice? If anyone has a similar setup with any pictures that would be great too.
I've had both. The BFG AT's looks okay, and they last, but they do nothing for the looks of a truck IMO, and they suck offroad. Trails look aggressive and eye catching and from what I'm hearing they are lasting 40-50k miles. You really can't compare the two tires for offroad usage anyway, as that's a broad term. Bottom line, your grandpa would rock BFG's.
Thanks for the info. Ive heard that the bfgs require a lot of alignments to get the full mileage out of then. Do your trails seem to wear any more evenly than the bfg's?
I agree, I just switched from Bfg's to Toyo's.
I got 46,000 on a set of BFGs right now with only the initial balancing. Rotated every 8000 miles at every other oil change. Ride fine and worn flat. I work on a farm so I don't need to tell you they haven't been cut any slack. Usually carry about 800 pounds in bed.
They are close to worn out but 50k is a good number. They aren't as rugged as the TGs but just as tough I'm sure. Not as mud capable. They look awesome to me. I love their white lettering. And your grandpa wouldn't run these, he would run some Michelins!
Sent from my Galaxy Nexus using Tapatalk 2
I've run both over the years. The BFG's were on a Dodge 2500 Cummins and they were fine for running gravel roads and highway but they didn't really excel in the mud. I'm on my second set of Trail Grapplers on my Sierra and they have been the best tires I've ever had. Worn evenly, mean as hell off-road, and have nice highway manners.
No experience with BFG. The trail grapplers provide good traction both on and off the road. I had this tire before. Also, these tires are not loud on the highway.
I agree with this. If you want a mudgrip, Trails. If you want an AT, BFG's. To me though, the price wasn't worth it for BFG's, and the Coopers I got ride better than them and actually helped fuel mileage, not to mention are pretty good in mud, sand, gravel etc.
ATZs are awesome!
X1000
I've always wanted them, but get to good of a deal on Toyo's :nonod: Unfortunately the shop is not a dealer for Mickey Thompson, so no dice.
The Nittos are a taller tire by size and narrower as well than the BFG. Nittos look cooler as well. Have had both as well as KM2s and Terra grapplers.
I assume your talking about the AT3's. Those tires have been getting some rave reviews online.
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
