Chris' 04 Sierra 1500 Fun Daily Build
Chris
  • Replies 699
I just calculated mine last night. 14.25mpg and that was all back roads. I don't trust those fuel economy gauges, not like mine has one, but I still do it by hand. Miles driven/ gallons put in. I even fill it up beyond the pump stop
I do it by hand a lot. The DIC usually reads .2-.5 higher than doing it by hand.
Sent from my Samsung Galaxy S4 using Tapatalk 4
I am trying to figure out the fresh side of the PCV. I think I will run a filter and check valve. I don't want to drill my intake tube
Im thinking about long tubes and cut outs to run between emissions test. Its something simple that can be changed within a couple hours for a testing appt then changed back. So that may be done with the cam. Im looking at 4.10s with a detroit locker now as well.
Now ur thinkin
What got me thinking about the headers is, I only test once every 2 years. Im rue in November. So in December I can fo what I want as long as I can somehow make it pass in November 2015 without having to drop a large amount of cash
That's the plan, Band claps and have a pipe welded to meet up with the Corsa cat-back
Had a minor accident so other than the repairs to my emissions system, putting on the TBSS intake and tires, other mods will be on hold. The only reason I will still do the TBSS intake is because most of the parts are already in hand. Looking at $800 before shipping and body work for just the parts.
Yea the hit was in the drivers side. Destroyed my tow mirror
Sent from my Samsung GS4 using Xparent Red Tapatalk 2
That frickin sucks! Sorry there about your bro's 4runner.
Well kill switches will be installed in the truck, G6, and whatever my brother gets, as well as my 17 year old brother's 95 Silverado when he starts driving
I have a set of DL3 mirrors on the way. They are 2 hrs away but it was cheaper to have them shipped($20) vs me going to get them($60). I should get them Monday and have them programmed Tuesday.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
