Chris' 04 Sierra 1500 Fun Daily Build
Chris
  • Replies 699
It came from Ontario. Sorry :chill: . Just a couple pieces left for this. But I have to do my emissions testing first. jerk.gif
I was told by Black Bear that going to 243 heads wasnt worth the cost of them. But I will still cam it. I will probably do a 2800 triple disc stall converter. Put the money I was going to spend on heads into the tranny or brakes.
My dad's 09 has 243 heads, and it doesnt put down much more power than my truck, stock for stock. Maybe 40 more HP, and thats with efans and whatever they put in the NNBS trucks. Maybe I just dont feel it cause of the 3.42 gears...
Yea but I would have them on my 6.0 not a 5.3
Sent from my Samsung GS4 using Xparent Red Tapatalk 2
Just ordered the evap vent solenoid. It sits on the fuel rail. It's for a 2008 Silverado 5.3, but the plug is the same. Also requested the tune change.
gind thevpart number and look on amazon. This one was like $24
Dug around and found a couple pics. One is of the brakes I put on it. One when I took the 20's off for a couple weeks in the winter.
The rotors
I ran the 16's for a while while cleaning the garage and had to go to the dump repeatedly
The alternator looks so good
4 on each top bolt, and then also got (4) M5x0.80 allen head bolts which were 30 mm long. I also put a lock washer on the outside of that retaining clamp. Used some 3/8" rubber pipe, cut it to length, which was like 9/16", and then cut it in two so it was "U" shaped. Super glued it to the top mount bracket, just one piece, used the other on the other side. That way it takes up that slack at the top of the mirror. Works perfect. Barely vibrate going down the highway at 80 now
You should level those mirrors. I just did mine last week and look a helluva lot better...
Im perfectly happy with the mirrors how they are
So another week of decent highway mileage. Not sure what to think
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
